Help with regulated +/- 15V PSU schematic
I want to build a good quality +/- 15V regulated PSU which I can use for general testing and using with opamps like OPA627, tpa6120 etc.
I purchased this kit:
http://www1.jaycar.co.nz/productView.asp?ID=KC5038
which is very basic, uses a LM320T15 fixed -15V regulator and a LM340T15 fixed +15V regulator and has 1000uF on each rail.
Anyway I want to make it better so I looked at Tangent's STEPS and took some parts of that and just put them straigt on to the Jaycar one.
How does it look? any improvements or mistakes?
Excuse the MS paint bits :D
Hi I think the kit from Hagtech makes more sense. (part of a phonostage kit)
http://www.hagtech.com/images/powersupply.gif
Stephen Soosai said:
Three terminal Linear regulator IC such as 7815 and 7915 can't do the job well enough..?
I dont understand. Whats the difference between 7815 and 7915 and the ones in the first schematic? I thought they were more or less identical.
Anyway I have made a pcb design based on the http://www.hagtech.com/images/powersupply.gif image.
costiss said:
if u are intending to design a pcb for this, have the traces much thicker.. especially for the ground, you should build a ground bus ca 1cm thick, so that you dont have any stray- loop currents through your pcb..
OK, thanks!!
I have redone it with a 6.38 Ground, its the biggest expressPCB will do and if it was bigger it would be tricky to fit under the diodes.
TL431's cost about $0.25 each and they are a great reference/error amplifier -- much quieter than the 7815/7951 -- the schematic below is gilding the lilly -- you don't need the post regulators (LT17161 LT1964 ultra-low noise -- they are surface mount anyway). This design will cost less and handle more current, the reference is set as Vout = 2.495*(1+R1/R2):
I give credit to Elso for the first part of the design, I modded it for the parts which I have on hand,
I am probably wrong but does this mean it will supply 100mA maximum:
"Sink-Current Capability . . . 1 mA to 100 mA"
If so, that is 10x less than the above regulators. I can see that it is a better design but it would cost me more as I would have to order the TL431 from RS components which will cost at least $10 for 2.
I am still not ruling it out though.
What function do the MJE1503x perform? why is it needed so high volts and amps? (150V 8A)?
Those aux transistors do the heavy lifting -- the TL431's supply a reference to the base of the Pass transistors. I use the ones shown in the schematic since I have hundreds of them in stock at my webstore. You can use whatever suits your fancy. The ratio of the two voltage divider resistors differs between the positive and negative supplies.
The LT1761 and LT1964 really aren't necessary unless you need power supply noise in the microvolts -- I just used them in a project from which the schematic is lifted -- they will only handle 100ma or so.
The protocol on DIYAUDIO, one which I respect, is not to flog your stuff, so if you are interested in parts email me privately. I have circuit boards too.
Thanks jackinnj :)
I'll have a think about this as I have many options now :xeye:
I enjoy making my own PCBs and the fact you are all the way in the USA rules out getting any parts from there anyway due to postage costs.
Could you use cheap small transisters intsead of the MJE1503x?
eg. BC338 and BC328? if not can you recommend a smaller transister that is more readily available than MJE1503x?
So this design would provide less noise than the design above or an LM317 based PSU?
7815
A little off the path sorry but I hopw not too far. Seems like the expertise I need is here.
If I tie a 15 or 16 volt source to the output pin of an umpowered 7815 and 0 to its ground pin will this damage it. I want to be able to jump back an forth between two supplies -- one on board and the other outboard.
Any thoughts thanks
To be more precise: If the smoothing caps are small and you for some reason has additional smoothing on the regulated side...and the discharge time is longer in the regulated side than the unregulated, then you need these diodes but normally you don't, espcelly if you have known loads but if you are going to make a general power supply you should have these diodes, just in case. They are for protection purposes only.
