Help with my D class Amp
Hi ALL
I want to create D class amp by my circuit (see attach.)
But there are 2 questions:
1)What about output FETs & driver? Will it work under 100 kilohertz?
2) What is the best way to make PWM controller?
P.S. This will be powerful (900w) amp for subwoofer.
As I understand IRF540n better,cause QG=47.3,and it is the main problem of IRFP260n?
And driver too. Try the search for "UcD"(22 threads):
About your AMP.
I calculate that the power is about
Pout~=600w @2 Ohm, or more - is it true?
I = P/U = SQRT(P/R)=17A
Ptemp=Pout*(1-n/100)=600*0.06=36w
So what about heatsinks.
Can I try your amp,because I have already spent a lot of money for my variants of D-class AMP :(
More powerful driver such as ir2184 should be working well with irfp260 charges, however body diode ~3 times slower vs irf540, and i haven't 200V(!!!) schottki yet. Why do you need such power amount? Did you hear 500W at 15" 93db@1W/M? (Mom too?;-) About heatsink, actually PCB 110x110mm screwed to the aluminium plate 110x110x12mm, all this is placed into the speaker box closer to the vent port.
Really-no, I have 12" 92db@1w/m 900w RMS 1800w MAX.
So,if I use ir2184 driver & irfp260 i can use your amploiD circuit with my irfp260n, of course also with more powerfull dc-convertor,with no changes in amp? And why did your need bc817/bc807 after driver?
can we talk by icq?
