Good afternoon.
My English is very bad, sorry.
I have the Marantz NR1604 locked, I need the firmware.
Could you send it to me by email:
41zirati@gmail.com
Thank you very much in advance
41zirati@gmail.com
2 People on this forum were so friendly to send met the firmware and instructions how to load. It resolved all my problems. Thanks for the help!I have the same problem with the NR1604 low volume when streaming. Work okay before but when I streamed via microsoft windows cast volume level suddenly dropped and can't get it back to normal. So worth a try to re-install the firmware. Please drop me a message or point me to a location where I can download the firmware for the NR1604. Help is much appreciated.
From now onwards you can contact me via this forum via diyaudio PM. No need to use this email anymore. Can be removed by the modirator. Thanks.
I occasionally face an issue that when I play audio via the Digital AUX1 entry (coax in) that when I start up my mediabox (connected to the Marantz NR1604) CBL in that I do hear the sound of the TV channel, but continue to see the Marantz logo page. When switching to the CBL input again no video only sound. When I do a reset by removing the power plug and put it in all works again. Any idea what could be wrong. Maybe a setting?
Got the same low volume issue on my NR1604 while streaming.
Can't sent any pm (yet).
Please share me the firmware at krebbers@gmail.com
Thank you very much.
I'm having the same problem after using DLNA. I just signed up and can't PM. @paulk1, would you consider sharing the firmware by either:
Thanks!
- making a file-sharing link - if it's allowed under this forum's rule 7
- attaching it to a post - if it's not too large
Thanks!
please can you send me the firmware, i cant write PMs... so please write to me ill send you my email... thanks a lot!Hi,
Yes, I managed to find firmware and it solved the volume problem.
Hello.
Would someone be so kind as to post the firmware for Marantz nr1604 ?
I have been having a problem with low volume for a few days now and supposedly re-uploading the firmware helps.
My email - brzeki.pszenica_0g@icloud.com
Please help
Please help
I also have same a problem with my marantz nr1604 please If I may send me too firmware to my e-mail adik424@gmail.com
I asked to send me the firmware for marantz nr1604 if it's just not visible Forgive me because I'm a newbie
Still at my marantz nr1604 also has a problem with HDMI, turning off while watching or freeze...
Has anyone encountered this problem ?
Hi @bucis, another grateful requestor for the 1604 firmware if you're still open to sending it. I can't initiate PM yet but maybe you can?
Thanks in advance.
I'm on 7300-7784-1432 and while I can't really figure out how out of date that is, I think it's pretty old. Some of the streaming stuff like spotify is unusable current state.
Thanks in advance.
Dear @bucis, yet another requestor for the nr1604 firmware. Many many thanks in advance!
My email is stijninnaples@hotmail.com.
Thanks again for your time and effort!
Kind regards,
Stijn
Kind regards,
Stijn
Dear @bucis can you send the nr1604 firmware and instructions to:
Lenard@snateren.nl ?
Many thanks
Lenard.
Many thanks
Lenard.
Hi @bucis, please send the firmware to robwilliams50@gmail.com. Thanks for your assistance!
- General Interest
- Everything Else
- Help with Marantz NR1604 Firmware
