HELP with Kaneda line stage PSU
Hello,
last summer I bought a second-hand Kaneda preamp, or to be exact a dIY preamp built by the previous owner following the Kaneda schematics.
English is not my mother tongue so I will try to explain the problem using my limited technical vocabulary...
So, this preamp sounds great to my ears. No, I've never owned any truly high-end preamp, but still it sounds a million times better than any "mid-fi" preamp i've owned, including Marantz, Rotel, Musical Fidelity, NAD, vintage Technics... it's probably quite easy to sound better than those, but the difference isn't marginal, it's very big.
Anyways, there's a major drawback with this preamp: noise. How can a preamp be "noisy" and sound good, you ask me? well, my speakers are horns (104dB), and the noise is only discernable in the absence of modulation (I suspect if my taste in music would be more towards piano sonatas I'd be much more annoyed by this problem).
The noise I hear sounds more like white noise, or pink noise i don't know, and is somewhat intermittent / variable, so I think the problem is in the PSU.
Now, i've never tried to use a soldering iron for audio projects, and DIY something electronic hasn't occured to me yet (although i'd really much like to try), but I can understand an electronic drawing to some extent.
Well, if I compare what I see inside my preamp (transformateur, two HUGE caps, and the main circuit) to the Kaneda PSU drawings I can find online, mine seems to have a lot of elements missing... only I can't really firgure out what... I'm joining a picture of the inside of my preamp.
Something tells me if I would correct the problem, not only the noise would disappear, but the preamp would sound even better. Maybe i'm missing out a lot here.
If the PSU is indeed incomplete, I'd like to add what's missing, or replace the whole PSU section; but I was wondering if it is possible to find / have someone make a Kaneda PSU board for DIY dummies like me?
I can find quite a few ready-made PSU boards on the internet but nothing seems to be ok for the 35VDC Kaneda... as far as I can understand it...
If someone could give me some tips / source me some PSU it would be fantastic.
thanks in advance,
François
Administrator
Joined 2004
Hello François - interesting question.
I have not built a Kaneda - though I've heard a few - but I'm sure someone here has a lot of experience.
Your version appears have the passive power supply, but is missing the choke and the second stage of filtering. It's hard to tell from the photo what else may be missing. I don't think the missing choke would cause hiss, tho.
Also: You are certain that the hiss comes from the Kaneda, right? If you disconnect it from the power amp, you have no hiss? No other preamp had as much hiss? At what level do you normally run the volume control? If it is always very low, you may have too much gain going into your power amp.
I will leave it there for those with more Kaneda experience.
I definitely have too much gain. I never go past 11 o'clock on the volume pot, and that is very, very loud -but then, it's also very loud because mys speakers are 104dB. Let's say with the volume knob at 11', the power-amps vu-meters average 10 watts. And that is with the power-amp input level controls set about halfway. The power amp on his own is dead silent, tho. My average power consumption is around 0,01watt... but the amp sounds full and clean even at such a low power.
The whole combo sounds really good; I don't totally understand this gain-matching stuff. The Kaneda is a high gain line stage, but i've always seen it used in hornloaded systems. So I don't really get it... also, if the gain is too high what is there to do? I mean, other that change all my electronics, wich I really don't wanna do...
I mean, no other combination has brought me such musical satisfaction trough the year, and as I understand there's a theorical mismatch here (high gain line stage, high power amplifier, high sensitivity loudspeakers) the result sounds good so either i'm deaf (but i don't think so) either there's some qualities in my system counterbalancing the gain problem...
on the other hand, no other preamp i've used exhibited any noise problem (or then u'd have to stick ur ear in the horn to hear it). But they also sounded like crap.
I think i'd try to make the PSU better, and if it's still problematic I'd maybe go look for another preamp... but I'd be hard pressed to find something that sounds as good as this one for cheap (I paid around 300$ for this unit.)
I'm on a very very low budget and my biggest electronic expense so far is my vintage power amp.
the original Kaneda is split in two preamp section : one is the RIAA and the other one is the preamp line section , i do not use this second section on my system , for cd only selector and pot to RCA (two set of out RCA one just after the pot and an other one after the line preamp ) enought gain on the direct for me .
Administrator
Joined 2004
Here is the schematic that I have for the Kaneda. I don't know if it's the latest, greatest. I agree with pioux that you probably have the second half only, the output section seen on the right half of the schematic.
Too much gain. It's a common problem. Still, I don't think that you should have so much noise from this circuit. There is a problem somewhere.
Until we find out what the problem is, you should reduce the volume on your power amp to as low a level as practical. Your Kaneda should be at about 11 o'clock for comfortable listening.
Start with the power amp volume all the way down and the Kaneda at 11. Slowly raise the volume of the power amp until you get to where you need to be. Once set, use the Kaneda volume control. That is a temporary fix for some of the noise.
that's similar to the mine , the french Kaneda have two output level , one just after the volume pot and the other one after the line stage .
on mine i us the first just after the pot .
this is due to Amp sensibility level .
I also use high level loudspeaker over 95 decibel for 1 w.
i think a test to add two outpup just at the volume pot could be a good way to test
thanks guys!
I forgot to mention also that the problem is acually volume-dependant. So the more I raise the volume knob on the Kaneda, the more the noise gets stronger. With the volume knob at 12 o'clock it's really strong. Strangely enough (i'm using a stepped attenuator, not a carbon pot) the FIRST lowest position ("0") on the attenuator is also more noisy than the second position. Weird.
Administrator
Joined 2004
That's strange as your attenuator looks to be wired correctly, and it's on the input, as it should be. But that kind of noise and behavior says "wiring problem" to me. Probably ground. But you indicate hiss or white noise, not hum.
Can you get a close shot of the preamp circuit board? Your photo is very clear and I can see the thru the PCB, but more detail would be nice. Push the wires out of the way a bit. Also, if you can flip it over and take a close up of the other side, that would be great. Thanks!
www.hifisonix.com
Joined 2003
There is a 3.8k (I think this is the value - hard to read) coming off the gate of T7. If you increase this resistor, you will reduce the gain. It looks like the gain is about 13x. Try taking the resistor I mentioned above to 10k - this should reduce the gain to about 5x which is more in line with typical modern pre-amps.
Kaneda DC1
You dont sell your Kaneda DC1 preamplifier?
