Help with horn for vintage driver
Hello im a new member of this forum. I have a pair of old full range speakers that i want to comute in a cool horn diy speaker since i have all the machinery foe wood cutting ect. but i don't know how to make the proper calculation in order to out down the cnc project.
Some help will be appreciated ...:)
I have a pair of vintage Philips AD 70650/W4 and a pair of tweeter AUDAX.
I couldn't find much info I put some pictures.
I was thinking to build a structure like the Khang audio horn speaker I already design the cad file.
Do u think it's worth the work or which cabit I should build for this speakers?
What we need are specs like these: http://www.diyaudio.com/forums/full-range/85921-cabinets-philips-ad3800am.html#post3925552
Do you know what the main differences [physical, performance] between your 7" and this one are? I'm guessing that since this one has a ~same Fs that its other specs may be also. Regardless, really need to measure yours as good horn design isn't very flexible compared to a typical sealed, ported alignment.
Otherwise, all I can do is a BIB pipe horn based on its published 45 Hz Fs and ceiling height:
BIB Pictures | Speaker Projects by Zilla
BIB Calculator | Speaker Projects by Zilla
http://www.diyaudio.com/forums/full...x-craft-handbooks.html?highlight=terry+cain's
GM
