If you've read it right and given it the correct info then WINisd is telling lies.ben62670 said:Would 2.2uf, and 29k work well?
These are the values I was given by winISD for 2500HZ.
I don't know which topology you are using, but for 10k expect somewhere around 2nF to 10nF to give 2.5kHz.
Nope...it's 29 ohms.I have read it correctly. It states 2.2uF, and .029 K ohms. Move the decimal point 3 places to the right, and I get 29K ohms correct?
use polystyrene or polypropylene for the smaller values. Try to find small polyester (MKT or MKS) for the larger values.ben62670 said:Are ceramic disk bad for XO's?
Don't use any ceramic, not even C0G/NP0.
I just 'upgraded' my system with Rod Elliot's design, the 'P09' which is 24db/octave rolloff. It's using TL072 op-amps which sounded great - no noticable signal degradation.
for my 3.5kHz cutoff the calculator returned 39nF and 820ohms.
http://gainphile.blogspot.com/2007/12/bi-amp-active-crossover-using-gainclone.html
- Design & Build
- Parts
- Help with active XO
