Help the Apex 550W Class-B?!
Hello all!
I want this amplifier 550W class-B to be processed into kalass-AB, and instead of diodes D3 (1N4148) and D4 (1N4148) for the bias, to put the transistor for bias, ... such as BD139 or similar?:(:rolleyes:
That's why people help you do that changes the pattern of this amplifier?
thanks
  • Apex 550W class-B.pdf
Hello all!
thanks
please check amplifier basics knowledge....
this amp is working in class AB
but you can add class AB +B for more output power
Radio,
if you don't know about ClassAB and ClassB biasing and can't determine how a Vbe multiplier works and why two diodes determine the existing bias, you should not be modifying any project.
Copy an existing working and proved project or learn how a circuit works.
Its simple, a resistor from C to B about 1k and a 1k pot in series with a 220-500 ohm resistor between B and E. and a cap between C and E.
Adjust pot for around 50-75mA per output pair.
Says tekko ....?!
Cheers
Regardless of what some may say , single pair MJE15032/33 should not drive more than 3 pair of BJT outputs. So , this is a bad design .. period. Besides that , no basestoppers , layout is not conducive to anything hi-fi. Slow down ... learn a bit more !!
For 500w/4R , you really need 6-8 pair depending on the SOA of the devices. At this power , a triple output stage is desirable , if not mandatory. Also , you would want your drivers to be outputs as well .... check out Rod Elliot's project 117 , this is the way !! LINK - Project 117
PS - only use older slow devices with this circuit , for new fast ones - I am working on that now :D .
OS
