What you asking is nearly impossible to help fix from afar. I certainly can't diagnose it for you unfortunately.
Unless you are fine with testing each of the components independently you definitely will want to replace caps and transistors.
Pretty much all parts except possibly the resistors, and I would check each of those. Especially the active parts will be suspect.
Sounds like its time for a Legato instead.
Sorry for the bad luck.
Cheers!
Russ
Cheers!
Russ
