SESS
There is Andrea Ciuffoli's SESS Tube Headphone Amplifier (SESS means "single-ended, single-stage, single-tube") :
http://headwize.com/projects/showfile.php?file=ciuff4_prj.htm
Keep it simple
I must confess that I am predisposed to like simple designs. If a simple amplifier also sounds good, I probably want it. Usually, if a more complex design is the only known way for significant improvement, then I will choose the more complex one.
On the other hand: If a triodised EL95 can give you about 1 W output then I am quite sure that a half of ECC83 can give 50 mW as well. If the headphone's sensitivity is about 100 dB / 1 mW then you have enough reserve for 117 dB. Do you need more?
Hi all,
I am planning to build Morgan Jone's headamp but i want it not only as headamp but also as linestage. Anyone can help me what modify the circuit for this purpose?
TIA
TIA
That should work as a line stage without modification.
R7 could be higher, maybe 470k.
Gain may be a little high... if so try reducing R8 to 47k.
Circuit assumes no DC on the input (or use capacitor).
Another version is here:
The Cavalli Jones Headphone Amplifier
For a linestage; yes, those values should work well.
However for a headphone amp, if the headphones are low impedance (30 R), then you may need R8 to be 100 k. The reason is that output impedance forms a voltage divider with the load, meaning that the gain must go (back) up to compensate.
Perhaps best is to make R8 variable from 47 k to 100 k.
Good luck with it.
Good luck with it.
Thanks for your help!
Good luck with it.
- Headphone Systems
- help on headphone amplifier
