Hi DIY fellows,
I am facing a quite irritating problem with a Sony CDP X303-Es CD player that I bought (sold as not working) : the disc tray keeps opening and closing as soon as the player is powered on. Of course it's impossible to play a CD.
As a first move I checked the switches sensing the tray position at each end : the are perfectly working.
What's next on the list ? Has anybody experienced something like this ?
The Service Manual is available here : SONY CDP X303ES SM Service Manual free download, schematics, eeprom, repair info for electronics
I suppose that if the system IC (Sony 1M3745) is playing havoc the CDP is good for a visit to the dumpster, which I'd prefer to avoid as it is absolutely mint.
Thanks for your help guys
This isn't mine but you can see it's a cool player !
check out the prozessor line-up without insert compact disc and open cover.
After tray closing the optical pick up (laser unit) goes shortly outside (in "end" position) and quickly back to the start position. At the same time the "inner-switch" contact for the laser unit closed. Through this was released the instruction for the processor to force the lens up and down (2x until 6x - dependend of the model)
During this upward and downward movement laser light goes on. After performing this laser light switch off.
If all this is to observe, put in cd and observe, whether cd starts to rotate.
If nevertheless no TOC reading happens, laser light is a bit too weak.
If cd don't start to rotate, laser light is out or extrem weak (or other error must be find).
KSS272A must be replace
An off-topic question: Please let me know the way for upload your photos (images).
I wonder to see your pictures without log-in and don't know the reason - thank you for your advice.
Thanks a lot for your input !
In fact the CD lens does not move at all. The tray just keeps going in and out. As soon it has reached the closed position it goes back outwards. In my opinion the lens is just not even given the order to read the TOC. There is probably somthing wrong with data sent to processor about tray travel. The CD doesnt start rotating.
Thierry
button problem?
Maybe the open/close button actuator or signal is stuck in the "actuated" position, as if you were holding down the button. Did you try to disconnecting the wires leading to the button?
Not sure, this is just an idea that popped into my head that could explain this behavior.
Nice unit BTW.
-Charlie
Nice unit BTW.
-Charlie
Nice unit BTW.
-Charlie
Mmhhh that's a good idea ! Let me try that and I'll be back for reporting.
Thanks !
Maybe a long shot but try changing the drawer belt. I had a similar issue with an older Sony CDP and a belt changed fixed it. Maybe the drawer didn't go in far enough to trip the limit switch due to the slipping belt so it kept popping back out again. I also have bent the limit switch legs on some Sony CDP to allow the drawer to stay in.
Boing ! Thanks for that one !
Indeed I noticed that the belt is greasy and it slips in the motor's pulley
Also, the motor keeps turning although the tray is in closed or open position.
Maybe there is a kind of motor load sensing circuitry and as far as the motor's load hasn't changed it considers that the tray travel isn't finished ? Recently I have fixed a Revox B225 wich had exactly the same problem, no belts in the Revox but the current sensing was faulty because of a dead capacitor and the tray was keeping going in and out forever.
I will clean dry the belt and the pulleys and let you know.
Thanks to you guys for putting me on the right tracks
Thierry
These belts can stretch or if not used for a long time get a little kink where it's been sitting around the motor pulley so the belt can slip at that point. I'm not sure if the motor has some load sensing but a slipping belt tends to not allow it to trip the limit switch.
A 1.6mm square x 37.3 diameter belt seems to suit all the older Sony CD players I have.
Also check if the drawer runs freely. I had a CDP-X55ES here where a service centre had greased the geared rack (underneath) with automotive grease which caused it to be sticky and took a lot to clean it all out. These run without any lubricant.
From my own personal experience with this Sony player . I had the exact problem that was drving me crazy. I tried ALL the efforts previously mentioned. Checked all micro switches , cables , motors ,belts. I was able to get the player to work with a 6 pole toggle switch between the drawer motor and servo board. The end of the story was that the servo board attached to the laser has a non fuctioning ic. I finally found a trashed Sony player(don't recall the model , but later one) with the same transport assembly. I swapped the board , and it's currently working properly. The 'new' board has some additional circuitry attached to it , so I think a rework was done by Sony. Hope that helps
I guess you are spot on with the IC issue. I cleaned dead dry the greasy belt and pinions (see pictures) but no joy
I suppose I will either try to find a compatible board as you did (if I am VERY lucky) or tear the player down to pieces, sell the salvageable parts and put the rest into the bin. The KSS seems to be good, I could see the red beam from the working laser.
Shame as it's such a nice player when used as a drive
What you show in the pics is exactly as I did SEVERAL times , convinced that I could fix it because the laser did light. Look at one of the dac/transport lists. There are a few with this same assembly. Took me over a year of checking ebay before I found one. I only endured because my unit is very clean , like yours.
Good luck
Good luck
Thanks for your feedback.
Problem is that I have no clue about which Sony model to look for, there are so many references.
Try this
CD-Player-DAC-Transport List
Your player uses the KSS-272a laser. Just look for other Sony's with this assembly
Just had a SCD X303ES for repair with the same complaint, i.e. tray coming out - going in and out again continuously without reading the disc.
The problem was in the small PCB under the transport.
There you can find a memory cap, C302, which leaked on the PCB and eaten away the GND connection of the IN and OUT tray switches.
So the system control chip was searching for the tray position.
Restoring all the damaged feed-through PCB connections under C302 and replacing C302 turned it into operation again.
Hi djmiddelkoop,
This post was so old I forgot it along with the Sony
Thanks to your contribution I exhumated the player from the basement where it was gathering dust since 4 years and looked at the PCB under the drive.
Nothing was wrong with C302 nor the tracks but when testing pin #2 on the connector leading to the IN and OUT switches (orange and with wire) I discovered that it was not connected to ground !
I just had to solder a short length of fine wire between pin #2 and the first ground plane next to it and the Sony was resurrected !
Thanks for putting me on the right track, happy Holiday and Merry Xmas.
Thierry
Thierry
Hi Thierry,
you are welcome.
I strongly suggest to desolder C302, the memory cap, it is bad anyway after all these years.
It looks fine on the outside, but underneath it leaks.
As you also found out, it destroyed the ground connection, which is a feedthrough under C302 to the other side of the PCB.
There are more of these feedthroughs there, in my case 2 others where bad to.
The problem is, if you leave it leak, more damage will be done, and that is a waste of such a nice player.
Happy Holiday and Merry Xmas to.
you are welcome.
- Digital Source
- Help needed with Sony CDp X303-ES player
