Help needed with PCB UV Exposure box
A good start
How can i mod the schematics below to include my 4 tubes? Seems i will need a >24W ballast but how many starters? Will 1 per pair of tube be sufficient?
thanks
More tubes
Thanks richie boy i forgot to mention this is a T5 tube. Can this type be powered without ballast and starter?
I've attached a new shcematic with 2 tubes is it correct? In case yes can i keep adding my other remaining 2 tubes in parallel as shown? This would mean 4 tubes in parallel 1 stater and a 30W ballast.
BIG Problems with my Tubes
Am back after some long time. I tried to experiment with my tubes in parallel or series as attached but was able to keep only 1 tube on. In the attached wiring its always tube 2 which gets on. From time to time 1 can get tube 1 but for only a few seconds but then tube 2 switches on and tube 1 is off. Could it be the ballast or something else?
If i connect only one tube it works fine but for two only 1 is on.
Thanks for the help
Thanks again richie boy but the thing that strikes me is how it is behaving so strangely as only 1 tube is on. By the way these tubes come from an insect killer they sell at Game store here. I've lighted one of the units but its really light. I wonder if these actually use a ballast inside????? Its not worthwhile buying one to dismantle it. In case i can i'll try another ballast just to check. At worst the only choice is 4 starters, 4 ballast :(
