Help needed for battery power suply
I need help for my new amp. It is a TDA8920 CLASS D Audio Power Amplifier AMP Kit 100W X2 se pic.
Im most confused about the powersuply as im using 12v batterys to power it and I don't really know how to connect the power to the amp.... It says ac2x20v(se attachment).... How do i connect it when im using 12 v batterys????
sorry for being a newb:scratch:
This amplifier was intended to use AC.
It should be possible to use DC, and even connect it to the AC inlet, but it would be better to have a view of the schematic before giving advice. If you have one, post a scan or picture of it.
It will not achieve the full output with 2 * 12V.
w
I dont have any schematics, so just some help would be great :)
I herd that i could make circuite with two batteries like the photo below.
I tryed it but it did not work.... The only sound was some low konstant clicking.
i dont think i need the full power for my project.
Connect your batteries at the electrolytic capacitors. In the bottom-side pic, neg-pos-neg-pos from left to right. I see in the TDA8920 datasheet "Operating voltage from ±12.5 to ±30 V" so I wouldn't expect a lot of portability without a frequent battery charge.
Ok to get it straight:
i can just mount the two batteries directly on the soldering on the backside of the capacitators: one battery neg-pos and the other neg-pos one on etch capacitator?
Should i then unmount the bridge rectifier? or should i leave it.
bu the way thanks for the help, i really need it:)
i can just mount the two batteries directly on the soldering on the backside of the capacitators: one battery neg-pos and the other neg-pos one on each capacitor?
What you state is essentially correct. You can leave the bridge in place.
Going directly to the caps avoids the ~ 1.5V drop added by the bridge.
Even so, given spec is +/- 12.5V it might not work, but it likely will.
rgds, sreten.
