Hi I need some help choosing some speakers for the loudspeakers I want to make (tweeter, midrange, woofer and crossover networks) my budget is around $2000 AUD I have no problem putting them together (getter some help from someone) it's just I am not sure what to buy or where to buy it from.
ps if you have any tips that might help feel free to post them
that's a pretty open question
There's so much great information from some very talented speaker builders all over this site. I suggest you spend a day or two reading some threads and come back with some more specific questions.
First choice, I would propose, is to decide on what kind of speaker you want to build, transmission line, reflex, open baffle. Then you can start looking at drivers.
My 1st advice, is that if this is your 1st speaker diy, start with something much more modest. What you learn from the 1st one will greatly inform you in terms of which direction you personally should go.... and be warned -- just like that delicious cookie -- you can't stop at just 1.
dave
dave
Hi sogens, welcome to the forum. In addition to what Dave has said, there are a number of threads started for us Ozzies. Brisbane meet being one. Other get togethers are being talked about.
You really need to hear some different system types before embarking on a project. We all have our favourites, you need to find yours. 2K is a big budget for a DIY, let alone your first.
Geoff.
Geoff.
You mentioned you wanted a 3way - any particular reason? Was that recommended to you?
Here is a site - never built any of the designs but I've never read a bad comment on them (only good).
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
If you feel a 2 way design might be more your thing try:
http://www.zaphaudio.com
Either way - unless your friend is an experienced speaker designer, don't just buy some drivers and a standard crossover - otherwise rubbish will result. Much like building a car from scratch and just buying an engine, differential, gearbox and chassis and expecting them all to nicely integrate and work well together.
Use a proven design from a proven designer, but first list your design goals and understand why.
Better still - put your design goals here (requirements) and let the experts give you some speaker designs (solutions) to meet them.
David.
David.
- Help needed building loudspeakers
