Hi all,
I need to replace a pot in a subwoofer preamp. It controls the freq of 2 2nd order Sallen-Key filters (or LR4), thus the 4 resistor elements. The circuit works fine if I insert discrete resistors although 3 of the end-to-end resistances are 3MR or more - so it's amazingly a failure of 3/4 of the resistive elements!
Please see the pics of the pot I removed from the preamp. I would describe it as: 4 gang, horizontal PCB mount, C taper, 50k, no click/detent, 12.5mm above PCB with 20mm long, 6mm knurled length, 18 teeth shaft.
I contacted the manufacturer of the sub amp, and they didn't design it and don't support it. The pot is marked with "HV" on the pot bodies, but I don't know if that's the manufacturer or something else. So no luck there.
I then looked at Mouser, Digikey, and other places in the US without any luck. Googling didn't turn up any parts. Can anyone suggest someplace (preferably in the US) that might carry this pot?
I found the part I need at Taiwan Alpha (part number: RV124F-21_-20K-C50K-_0) and Alpha Products (part number: Alpha Products 3RP/1240G 2 A B C 50K 0), but neither one had the part available and would require a 1000 piece order to make any. Although I will say that the Taiwan Alpha folks were exceptionally generous and courteous to me. I also found a few Asian suppliers with seemingly compatible parts, but I didn't contact them because I'm not feeling like it would be worthwhile.
Any suggestions of how to get a replacement pot would be wonderful. TIA!
Ebay seller familygate has lots of Alps pots. Here is a 4-gang log 10K or 50K pot, but its motorized:
eBay.ie: ALPS Quad Potentiometer RK27114MC motorized pot 10K 50K (item 250467804650 end time 16-Mar-10 07:46:33 GMT)
They do have a non-motorized version, but I only found 5K or 10K (but did not look exhaustively).
I've read that a 100k resistor across pin 1 and 3 of a 100k linear pot will make a 50k reverse log.
I'll amdit I don't have the math skills to cofirm that though.
OK, I guess I read wrong.
After more searching and reading, it looks like you can take a linear taper pot of 5x the value you need, and the put a resistor of 1.25x your desired RevLog taper across pin 2 and 3.
50k x 5 = B250k
50k x 1.25 = 62.5k
So for C50k, you put a 62.5k resistor across pin 2 and 3 of a B250k.
I did a search at google.com for
quad concentric pot OR potentiometer
and found this PDF about a family of modular pots and switches that can be configured however you want (up to four sections concentrically):
http://www.potentiometers.com/pdf/catalog70.pdf .
And the link below has new and used parts for Tektronix and HP/Agilent test equipment, which includes lots of interesting pot configurations (and lots of other cool parts!). Maybe it'll give you some information about who makes what.
Tektronix Electronic Test Equipment Parts - Pots, Resistor Networks
Tom Gootee
Tom Gootee
Do a search at google.com for:
multi-gang pot OR potentiometer
Note that the "OR" must be in upper case (caps).
Also, you might want to check out the Vishay / Sfernice P9A series. They can have up to seven modules on a shaft. Mouser.com has the dual 50K (but not sure if they carry other than linear taper). You could probably buy two of them and make them into a quad. Go to mouser and search for 72-p9a. You can see an older mouser catalog page with them, here: http://www.mouser.com/catalog/629/544.PDF . (Looks like the price on the dual 50k linear ones has about doubled since then.)
Joined 2007
please check this photos, Does it same as your need ?
You can add my MSN garyhjj456@hotmail.com
Gary
Gary
Joined 2007
Hi Garyepe,
Yes! Well, almost. The lead spacing is a bit different, but the pot you show may work for me. I would need to the B0 circuit configuration with either KQ or KR shaft style. There are other parameters, like resistance value, taper, etc. that are also important, but it looks like you're showing physically a compatible pot.
Email sent.
Email sent.
Joined 2007
this looks similar to the frequency pot found in an old peavey V4-X crossover.
the peavey version is only 3-gang (18dB/Oct), but if its still available, it might be worth cannibalising
also check the low-pass / high pass frequency pots in the peavy EQ-31 graphic - i think these were 24dB/Oct.
- Design & Build
- Parts
- Help me find a 4-gang, 50k pot?
