bogdan_borko said:how to calculate output impedance of these amp stages?
Hi bogdan_borko
Amp stage A - the output impedance is the value of R4 in parallel with R5
Amp stage B - 1/Gm ( Gm is the transconductance of the mosfet ) in parallel with R9 and R6.
Cheers
Re: Re: help ! how to calculate??????????
Actually, assuming R5 in amp A and R6 in amp B are the load, then what you have written is the total load the amp sees, not it's output impedance (this does not include the load). So, for amp A it would be R4, because a MOSFET is a voltage controlled current source, and current sources have very high impedance (ideally infinite), and in amp B it is 1/gm of the MOSFET at the chosen operating point in parallel with R9.
Tube_Dude said:Amp stage A - the output impedance is the value of R4 in parallel with R5
Re: Re: Re: help ! how to calculate??????????
Hi ilimzn
But if you assume that R5 and R6 are the DC current path for charging the capacitors C2/C4 and part of the design , the output impedance is calculated as I have said.
Hi ilimzn
