finally....
Hi all,
I am sorry for the late reply but I'm very busy with an important loudspeaker project ( that is my expertise) for a obsessive friend, nearly incontentable
We have made a PCB for the 6N6P-I.
B+= 200 volt ( mosfet series regulated)
filaments: AC
anode resistor : 5,6K allen Bradley ( 95 volt across)
cathode resistor: 100 ohm allen Bradley ( about 20mA-each triode)
output cap : old Siemens mkp 1microF
Load: 100K with 1500pF in parallel
Gain: 10,6 times (unbypassed cathode)- 14 times ( bypassed)
-3dB at 40 Khz ( unbypassed cathode) - ( bypassed) 60 Khz
measurement are performed at 17,5 V out RMS undistorded
This puppy looks incredible, THD are better than a cathode follower of 6922 !
I' m quite pleased for now.
Today I'll test microphonicity and start serious listen.
I want thanks you all kind guys and expecially Gordy for very precious help. Sure in future I'll need others suggestions again
If all will be good, next steps 'll be a new PSU
Paolo
Hi all,
filaments: AC
Paolo
Thanks Lars,
Yes I was suspecting a similar result. Not bad ,eh?
Are those date precise or extimate?
Frankly I was expecting a little lower values for Zout but
measurement of -3dB point on high frequencies seems confirmate your statements.
I think this 6N6 have good gain and appreciable low Zoutput,
exactly what I need for drive my power follower.
Maybe I am wrong but there are not so many other tubes with these
carachteristics . 5842 ( not my taste), 6C45P ( not tryed).
What other?
Forgot to mentione that the two half-triodes are extraordinary good matched!
Now I have fear to check microphonicity...........too beautiful to be real!
Paolo
What other?
Paolo
First bad surprise: one channel is very little microphonic
I'm fanatic about not-microphonic, no need to explain other.
I have others 9 valves to test, very annoing!
I was too much well accustomed with my old sowtek 6922, zero microphonicity, maybe I' pretending too much.........
It is a pity, hovewar, the others "traditional" tests looks fantastic
for this 6N6P-I.
Paolo
for this 6N6P-I.
Paolo
the sound of 6N6P-I
after 10 hours of break-in ,
the sound is very different from my previous 6922 cthode follower
In short, I am amazed how good this 6N6 sound. In comparision , cathode follower is near unlistenable. Finally the entire system sound
full, hot, harmonic,dinamic .....it is incredible
I suspect 90% of this is due to the anode otput versus previously cathode output more than 6922 per se.
Maybe also the big current capability of the 6N6 is important to drive correctly my mosfet , I dont know
Anyway I am relistening all my favourite albums just for pleasure
and they sound incredibily natural, like a monotriode with the brute force of a big solidstate
Paolo
Paolo
That's a tipoff that either the CF was poorly designed (very common) or what you were using to drive it was incapable of hitting your voltage requirement and all you needed was some gain or to fix the driving source.
Glad the project worked out!
Thanks SY,
I 'm not sure of your sentence, first because previously 6922 was designed by a very well regarded EE here in Italy ( no name because I do not want make polemic) , second because when I and my friend have tested it on the real load ( 100K- 1800 pf) , the "scope" show good performance up to 10-12 V rms. Quite sufficent IMO, output mosfet clip before that level.
Maybe I am a newbie and do not know what I am talking about, perdone me !
I am glad too this puppy is sounding like a real triode
Paolo
Paolo
Hi guys,
Just a curious comments after some listen ( 50 hours)
I have to disagree with myself and my previous statement about monotriodes!
I have noticed a huge difference bypassing the cathode resistor.
IMO this is because the 60Khz ( -3dB) versus the 40Khz ( -3dB).
Bypassed sound a lot better ie unbypassed sound "closed", incomplete. Imaging also suffer a lot.
I am not familiar with tech specifications so I have searched some data. Well, if I am right, 40 Khz of upper limit is considered "good" for
a SE triode amp. without feedback. Very good transformers .
So I am confused, am I missing something ?
Paolo
Paolo
Hi again guys,
Yesterday I have made a decise improvement:
Swapped the electrolitic cathode bypass with a decent MKP, same value. Wow!
Incredible difference. Gained super dynamics on the mid-high zone,
grain is near zero, and the soundstage seems " stand-up"
But this have altered the previous "equilibrium" so I had to adjust the
x-over levels to compensate just a bit of course
I am very happy . A friend have just listened and he ...
Next future plans are new PSU. Very important IMO.
shunt-Regulated or unregulated ?
CLC or LCLC ?
Have to learn a lot on this "subject"
happy new year ,
Paolo
CLC or LCLC ?
happy new year ,
Paolo
Hi Erwin,
5,6Kohm on the anode
100 ohm on the cathode ( bypassed mkp)
B+ 200V
-3dB at 60KHz with 100K 1500pF load
gain 14 times
distortion not visible on the scope up to 17-18 V RMS
Zout I don't know but presumed about 1400-1500 ohm
Maybe I would be try a more hard point of work, more tension and more current but I am not capable to read "6N6P-curves".
I am very satisfied. It SOUND !
Full, solid, robust,hot, harmonic-structured. This valve is very good!
Now I am thinking about PSU........would be 5R4WG Chatam, LCLC.............the problem is the input choke......very expansive and difficult to find one absolutely noiseless ( 40mA current)
Have to reflect........
Paolo
B+ 200V
gain 14 times
Paolo
inertial said:Hi Erwin,
B+ 200V
gain 14 times
Paolo
Hi Paolo
thanks for the reply. pardon my ignorant, you are using 6N6P right?
do you use any input resistor on the grid?
do you use each tube per channel (parallel) or one tube for 2 channel?
what kind of amp do you use with this? as i have 100W hybrid amp and i am using diy tube preamp with gain of 8. there is too much gain in my system. Anyway to bring down the gain?
thx in adv
hi TweekerTweeker said:Spend that money on active regulation. Cheaper, lighter, and your more likely to hear a difference, DCR<1, some way less. Also, less mechanical and EMF noise headaches to deal with.
newbie questions, can you please post some links about active regulation? any schematic? thx in adv
Erwin
milen007 said:
Hi Paolo
thx in adv
Erwin
HI Erwin,
6N6P-I indeed
820ohm grid stopper
half 6N6P for each channel
This is my amp ( I have a biamp, this is only for the mid+tw)
http://www.audiodesignguide.com/PowerFollower/index.html
your problem with gain maybe (can) has a symple solution:
what is the gain of your hybrid amp? 10 times, 20 times?
In this case IMO you can jump the preamp and put a pot on the input of your hybrid...
Paolo
Hi tweeker,
Thanks for suggestion but really now I have a regulated PSU ( series type with mosfet) : it works electrically perfect but the sound....mmmh, it seems to me a solid state preamp!
I have two options:
1) Shunt type regulator
2) unregulated, tube rectifier and LCLC .
I will have to try both!
Paolo
hi Paolo
thanks for the reply. have you try the Salas' shunt reg? i am looking at it and may want to build one and saw you posting on that threat hence i assume you interested as well.
i have no idea bout the gain in my amp. i only know its rated 100w per channel. think the gain 7-8
Only 7-8 times?
It's strange if it employ tubes front-end....unless it use overall-feedback !
Do you have schematic? What brand-model it is?
About shunt reg, I am in very busy phase. I have a big speaker to
design and I am also thinking to swap digital source with another.
Big works. I have to programmate each phase to not make confusion!
Don't know when but I'll do it..........
Paolo
Paolo
- Tubes / Valves
- help for E182CC linestage/driver
