On the subject of power supplies. I am going to look into getting a custom toroidal from :
http://www.airlinktransformers.com/toroids.htm
A 50va with 2 equal secondaries at an order quantety is 7.90 so I would imagine a custom 60/9 secondary wouldnty be too much more. If it was £10 (obviously not inc postage or vat)would there be any others in the UK or europe interested ?
dave
dave
On the subject of transformers:
I just ordered 2 transformers in Germany.
These are 2x48V + 2x8V, so you can get 2*54 V. Enough to use for a standard BOSOZ.
They are kind of expensive, but well made and on stock. I already used the lower voltages in my DAC.
expensive transformers
Greetings, Harry
Greetings, Harry
I like the little terminal block board they mount on the transformer mounting bolt. Neat idea.
Hi there People
Nice to hear things are happening with the boards. I am having some trouble sourcing the mass of diodes for the PSU. The only list I have been able to find is Coulombs . I am in the uk and 20a rated zener diodes dont seem to be common. Do the zeners really need to be rated that high ? what would be the lowest value. The problem parts are listed below. Any help much appreciated.
1 1N5235B
5 HS241-ND
5 BER147-ND
8 MUR815OS-ND
8 1N4739
3 1N5230B-T
2 HS241-ND
2 BER147-ND
1 1N5235B
5 HS241-ND
5 BER147-ND
8 MUR815OS-ND
8 1N4739
3 1N5230B-T
2 HS241-ND
2 BER147-ND
you are correct. I was looking the product number up on a uk site (see below) and the ratings are different. Doh thanks for pointing out the obvious.
http://uk.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=4502413&N=0
Will these diodes work ok ?
http://www.digikey.com/scripts/DkSearch/dksus.dll?Criteria?Ref=19628&Site=US&Cat=31195818
they are ultrafast to-220ab 8a 600v
Kari said:Our boards arrived today! Packing and shipping is under work rightnow.
/Kari
Can't remember if I sent you my adress by e-mail......
How do u get the adresses, paypal?
steenoe said:
My apologies, I must have misunderstood the situation. Eagerly awaiting the boards.
SteveA
- Heatsinks for Bosoz?
