Heatsink For LM4780
Joined 2011
I have a rather small heatsink for my LM4780's.
Each chip is running in a parallel setup and I'm limited on space.
Because of this I am building a detached power supply.
My heatsink is vertical fin 3.5" wide, 3.75" High & 1.5" fins with a .3875" thick base, there are 16 smooth fins.
I have another heatsink that I was thinking about using as the pressure plate to hold the chip to the heatsink.
What do you think?
The heatsink pressure plate should assist in thermal dissipation.
