I apologize for the newb questions and please redirect if there is anywhere more suited to ask this. I was soldering a new 1/8in jack connector for my headphones and realized that for each channel the signal wire seems to touch the ground wire (no visible coating for each) throughout the cable and yet the headphones work fine. Why isn't there any shortage? Am I missing a basic cable principle?
Thank you guys
Thank you guys
Friends often ask me to fix headphones for them, they always seem have enamel coated wires like the ones you've described. The easiest way for me to work with them has been to melt a ball of solder on the tip of the element (~40w) and run the wire through the solder slowly, this seems to melt the enamel and tin the wire at the same time. Hope that helps!
- Headphone Systems
- Headphone cable wiring
