I design the PCB's, print them out in b&W and copy to clay paper. Its the toner transfer method, some PCB's turn out better than others. I have a few that the top graphics are a little weak. This is a pic of the PCB set for the preamp: consisting of the RIAA, tone control, headphone amp/preamp, main power supply; dual 12 vdc, 240vdc, and RIAA power supply for the elevated 12volt for the SRPP heaters. I learned from the last one that you can make simpler power supplies, but you can hear them!
I still have several components to scrounge for the last? order. THen its time to fire it up!
Excellent work.
