Steven said:His name is Robert Cordell, see http://www.diyaudio.com/forums/showthread.php?postid=330984#post330984
Steven
Yes Steven, I stand corrected, Robert it is, my memory suffered a lapse as it is some years since I last looked at his paper, however it does work. I have built a 100W version of this with some changes.
Re: Re: Hawksford error correction
Well...yes it is, but as the feedback is applied to a less than unity gain output stage, it could be seen as a servo amplifier, but whatever it is called it does greatly improve the transfer linearity of the output stage without attempting to deal with this via an overall feedback loop.
Nelson Pass said:
I don't believe this is thought of as a feedforward correction
scheme, rather it is a local feedback loop around the output
stage.
I don't believe this is thought of as a feedforward correction , rather it is a local feedback loop around the output
stage.
I'm with Nelson on this one. The term feedforward is bandied around a lot in ways which aren't justified, IMO.
I think one could be justifiec in calling something like the Tekronix CASCOMP differential circuit a type of feedforward error correction; nested feedback loops don't count; calling it feedforward is just window dressing.
~Jon
I get confused about this as well, but I am pretty sure that it is NOT feed-forward. It is a local amplified feedback loop that might have some intrinsic advantages. I have never tried it, myself, but with a rock band power amp, it might be just the thing.
The reason for this is because, IF you have a fairly high crossover distortion (open loop) in the output stage, then this may be just the circuit to fix it, before applying overall feedback, if you wish.
My colleagues, Nelson Pass and Charles Hansen, apparently have tried it, and Charles, at least, doesn't like it much. This is a disappointment, but oh well, we just have to keep trying for better audio quality. ;-)
This circuit I'm using in my amps more than fifteen years ( Thanks Mr. Hawksford, Thanks Mr. Cordell ) and I highly recomend it. If is this circuit used, distortion fall more than five times. With 2SK 134 / 2 SJ 49 was measured distortion ( Ap ) less than 0.05 % on 100 kHz, 1 dB below clipping, which is for every Ayre's and Pass's only border of dream .
Upupa Epops said:This circuit I'm using in my amps more than fifteen years ( Thanks Mr. Hawksford, Thanks Mr. Cordell ) and I highly recomend it. If is this circuit used, distortion fall more than five times. With 2SK 134 / 2 SJ 49 was measured distortion ( Ap ) less than 0.05 % on 100 kHz, 1 dB below clipping, which is for every Ayre's and Pass's only border of dream .
They will argue that distortion is of no importance
Just one photo from the non-competent Czech designer (me) from the HighEnd 2004 exhibition in Prague, the preamp displayed is mine and was chosen for presentation of Wilson Audio Sophia:
jarek said:There are people listening to the music and people listening to the THD
This is the complete nonsense what you are saying.
Music vs distortion
In any note composition is written anything about distortion. I am very surprised, that John Curl, designer which is known by his constuction with very low distortion, defend oposite ones . - is it friendship with " old giants " ? I'm listener of music and distortion ruin the music, not upgrade. Change this view at last, it comes from people, which don't know make amp with low distortion and amp is amp, not musical instrument.
Oh! but I don't like THD.What will i do?There are people listening to the music and people listening to the THD
thanh said:(snip)Hi janneman! Are you a beautiful girl?
No, I have to work for my money.
Jan Didden
PS Took the liberty to correct the spelling of my nickname.
my dictionary hasn't it. Is it equivalent with hate?stink
- Hawksford
