Hi everyone,
I don't know how i managed to blow the power stage,i was just adding 2*electrolytic capacitors on the secondary (2*4700uF//2*1000uF) then startup and blowing of the irf740 and ir2113.
N-channel,
my 12V auxiliary supply comes from a 50Hz,3.2VA transformer+bridge+reg 7812, which is onboard.
I'd like to get rid of this supply by using an auxiliary winding and a startup module as you did.
I'd like to know how the auxiliary winding blocks the startup process.
There must be a huge dissipation during startup (fortunately fast i suppose)
Eva,
I've tried to replace IR2113 (I don't have anymore,and i don't want to replace it everytime a failure occurs) by a transformer to feed the gates (12turns:12+12) with different kind of small toroid cores but with no success (no signal on the secondary...)
Could you tell me a little more about transformer gate control
(type of core,size...)
SG3525 delivers a square signal(+10V;-10V) with 10%deadtime between pin 11 & pin 14.
Thanks for your international support !
N-channel,
Eva,
Maybe you was using toroid from some sort of inductor? Iron-powder&MPP and similar low permeability materials dont work in gate transformers.alexclaire said:Hi everyone,
You need high-permeability toroid core with something like 0.5 square cm cross-section. Most of usual ferrite materials like 3c85 and 3c92 can be used.
alexclaire,
At least for experimentation, you can buffer the outputs of your IR2113 with either emitter followers or IRF7343 dual N/P channel MOSFETs. You can use the easy source follower configuration with the IRF7343 since it has such low threshold voltage figures. Once I used the latter method, I was able to blow lots of IRF840's without blowing my IR2113. I think you should be able to use a resistor in series with the N-Ch gate to slow down the turn-on if needed. The IRF7343 is one of the few surface mount devices I have used much at all, and the SO-8 is the smallest I use, but only for MOSFETs.
Start 'er up!
Alex,
I was able to "turn off' the zener-pass regulator ckt by setting its output voltage 4-5V lower than the output from the auxiliary winding, ~16V, so this back-bias of the 1N4001 diode (in series between the TIP50's emitter and the Vcc pin of the '3525) effectively shuts off the pass regulator. Since the zener reference gets its power from the +320V bus via two 220kW resaistors in series, the power dissipated by them is minimal (on the order of ~20mW), so no big deal there. Since the big dropping resistor is two 8.2kW 5W resistors in series from the +320V bus, this dissipates ~5-6W for only a few seconds, if that long. Once the TIP50 is biased off, it no longer dissipates any power, so this is how it shuts off.
Joe-
I like the idea you present regarding high-current buffering of the IR2113's outputs to keep them from blowing. I shoild look into this. I am suprised, however, since both Motorola and IR rated the 2113s outputs into +/-2A.
Steve
Alex,
Joe-
Steve
Steve,
I think it is because those two amps can only pass through the chip for a short time. The internal resistance of the outputs of the IR2113 is several ohms. 2^2 * 7 is 28 watts. The chip will blow in a few milliseconds at that power dissipation level. The buffers are rated over twenty amps continuous--a very great difference. They even protect the outputs from negative voltage because of their body diodes.
Oops, I meant reverse voltage.
Maybe one reason for blow-ups is trace inductance on driver chip output? Output voltage kicks below ground and intrisic thyristor mode self-destruct activates?subwo1 said:Steve,
UC2825 controller for example has +-2A outputs, but all hell breaks loose if you try to drive something with it without schottky clamping diodes on output. I consider these high-current outputs pretty much useless as they require bulky 3A low-Vf schotkys on output to keep them alive.
mzzj,
Your thoughts make sense. I have used that protection method, but I feel that the IRF4373 source follower buffer method is better in many ways, including compactness. The source followers protect the chip from having to to drive excessively low DC impedances like shorted gates, too. I have used 1 amp Schottkys instead of 3 amp ones, but they may not give enough protection compared to the 3 amp ones. However, once I thought of the IRF4373 source follower buffer way, I was hooked on it since it does the job of the Schottkys and more.
One thing I don't like about transformers is that they seem to need low impedance drive themselves if they are not to load down the control circuit output. I don't like winding them either. I guess they would be OK with most of the standard controller chips which can drive MOSFET gates directly, anyway.
I like the IR2113's CMOS inputs, too. It also has enough instantaneous current ability to drive the hefty IRF7343 buffers without increasing rise and fall time. Small transformers are a problem with regard to creepages and circuit placement, IMO, too.
Eva said:...power it...
I do like this advantage, though.
IRF740 casserole
Alex,
All this talk about your supply has re-ignited my interest in re-assembling my old SMPS. Thing is, in trying to remove the '740s today, I broke the gate terminal off one of them. My last Motorola IRF740 has gone the that big MOSFET in the sky! I do have a couple rails of MTW20N50E lying about. At 20A and 500Vdss, with 240mW Rds(on), I guess I will use two of them.
Joe, the gate capacitance of the MTWs varies from 3900pF to 7000pF. Do you think I should look into the source-follower buffer you mentioned?
Steve
Alex,
Steve
SMPS
We do our off line supplies a little differently. We use TL494 driving a set of PNPs which drive a small gate drive xfr. Regulat half bridge configuration for the main switchers. We do not use TO220 fets bur rather IRFP360N. These are more robust than the smaller guys.
Advantage of the use of the drive transformer is that my TL494 can be at audio ground potential (It is always driven by a small houskeeping transformer) We apply full balanced feedback from our secondaries which allow us to keep the output voltage constant whether loaded or not. The seondary used a common mode choke and the transformer is wound to give about a 25% overwind ratio. Feedabck resistors at the TL494 set the final value of the output
We have used the IR2113 chips, nice but no isolation. Opto coupled feedback is required but this does not allow us to have the perfect regulation we have with balanced feedback.
At 62KHz the transformer you want to use with the amount of power you want is way to small. Check the charts on the Magentics web site
Steve
Steve
Re: IRF740 casserole
Steve,
I think probably yes. In a standard type design (not ZVS) for efficiency, it can be good to have extra drive, especially to turn off the MOSFETs quickly because that is when they dissipate maximum power. Also, you can be more confident that you won't blow your IR211x MOSFET driver if you should decide to experiment with the circuit. If you would like me to clarify anything about adding the IRF7343 buffers, feel free to ask since I am not sure if any information is available from other Internet sources.
MOER,
thanks for relaying that information. It is good to see what has worked well for others, especially with regard to future work in which we might like to try new things, or if we encounter a problem which something we read about on the forum might solve.
Steve
Steve,
MOER,
Hi Folks,
Try this link offline smps of pulse series amps from Crown:
http://www.crownaudio.com/pdf/legacy/s-c650as-03.pdf
K a n w a r
K a n w a r
- Power Supplies
- Half bridge smps voltage drop problem
