What is the operating definition of the back of cabinet watts rating? What does it mean?
Would a UCD-400 sound better than a 9130? I, also, am considering using my empty PRO-1200 chassis for something similar.
Dick
Actually, I just noticed on the back of the 9130, it says max power 600 Watts,
Dick
Means it pulls 600 watts max from the wall.
The UCD400 (Class D) is 400wpc into 4 ohms. If its power you need, then this is it. Sound is very clean and tight.
I have not heard the 9130 as mine is fried, but a UCD400AD sounds very nice. I have a UCD400AD and it is my favorite amp so far.
After I finish my Class A Aleph 60 and Krell clone (still awaiting two chassis'), we will see which one "ranks" and stays in the system.
I am betting the Krell, then the Aleph, then the UCD, but I wouldn't be surprised.
The stereo UCD400 requires a transformer of at least 500VA and 40VAC secondaries (can be used with less Voltage for less than 400WPC into 4 ohms). The sinks are largely not even required as the UCD400 barely gets warm (Class D again)...a Very "Green" amp. The "Tree-huggers" love it.
Lid off - how to get inside amp ?
Ok, so this applies to SE 120 power amp.
Undo top 2 screws each side, at heatsink top.
Undo top 1 screw each side (next screw down on heatsink at back).
If it has a lid as tight fit as a ...., then you need to use two hooked pieces of metal. Fit one each side in the ventilation holes (facing away from vents, to avoid bending) through the lid; then pull up on the hooked 'tools' with pliers. Slowly. This will ease off the lid and you can get access to the inside of the amp.
Never known a lid fit like that before. Wow !
