2SK 1058: Transistor 2SK 1058 bei reichelt elektronik
2SJ 162: Transistor 2SJ 162 P-FET 160V 7A TO-3P bei reichelt elektronik
CPH5901G-TL-E ON Semiconductor | Mouser Deutschland
Mouser has them too:I will go with the CPH5901 rated 12-20mA idss.... found at RS
No.... risk that the laterals are fake...
what is the minimum class A bias current when 2SK1058 & 2SJ162 start to sing?
I don't need more than 5W, PSU will be 30V
not having a lot of heat-sinking, I would like to use the strict minimum bias where the mosfets start sounding good...
with IRFP it seems minimum is 1A?
What amp do you mean and what speakers/load you want to drive with it ?what is the minimum class A bias current...
your amp of post 164 (pream with laterals as buffer for output)
Gyrator loaded Son of ZV9/F3
page 17
page 17
- Gyrator loaded Son of ZV9/F3
