Patrick - Double check my calculations, but I would like to send the exact resistor needed for each set. You subtract to get the difference between p-channel and n-channel, then divide by .007, 7 mA. That will give you the resistance to place in series with the set measuring the highest Vgs, correct? Since I haven't seen the directions yet I'm picking up from what was told to me to match the sets.
Applying your numbers to Fran's example I get 53R added to R3t (20R subject to change) = 73RPatrick - Double check my calculations, but I would like to send the exact resistor needed for each set. You subtract to get the difference between p-channel and n-channel, then divide by .007, 7 mA. That will give you the resistance to place in series with the set measuring the highest Vgs, correct? Since I haven't seen the directions yet I'm picking up from what was told to me to match the sets.
Do not use my calculations, they are not correct. Wait for Patrick to provide the correct values for each resistor.Applying your numbers to Fran's example I get 53R added to R3t (20R subject to change) = 73R
- Group Buys
- Group Buy for mosfets for FC CEN IV through hole US and Canada ONLY
