Great FU50 SE 12Wx2 tube amplifier kit!
Features and spec:
5Z3P tube rectifier
6J8P preamplifier
FU-50 power amplifier
Output Power 12Wx2
Load: 4Ohm or 8Ohm
Silkscreen stainless steel chasis
Part List
Tube and socket
- 8Pin tube socket x 3
- FU-50 socket x 2
- 5Z3P x1
- 6J8P x 2
- FU-50 x 2
Capacitors
- 450V/330UF x 1
- 400V/47UF x 1
- 400V/22 UF x 1
- 0.47UF film x 2
- 35V/470UF x 2
- 100V/100UF x 2
Resistors
- 39K 3W x 1
- 220K 3W x 1
- 1K 3W x 4
- 470K 3W x 6
- 680Ohm 3W x 2
- 100K x 2
- 100Ohm x 2
- 4.7K x 12
Accessories
- Silkscreen stainless enclosure
- 150W power transformer
- 3.5K to 4/8 ohm OP transformer x 2
- 2H 250ma choke coil x 1
- RCA connectors x 2
- Power switch x 1
- Output Connectors x 6
- Cables
- Shrink tubes
- Shielded cables
- Rubber foot x 4
- Wiring cables
The link: FU50 12W x 2 tube amplifier kit
Product Images
