NUKES
LOL.
Who are the other players?
The reason people asked is simply because at that price they suspect a compromise.
As John pointed out,sectionalizing reduces stray capacitance but to do that the winding machines have to be stopped and started several times.
And that costs money.
You and Saddam eh?
LOL.
Speaking only for myself, I was curious to add another datapoint, and my interest in the chokes was for another application. When I make my next "heavy" order from AES (ie surface shipped), I'll oder a couple and see for myself (including measurements).Joel said:Ok John, then why was everybody, including you, so eager to hear what the capacitance of this choke was? I was told this would "settle the issue".
WRT to your goad about the measurements of other brands, I don't own a single plate choke any more, prefering CCS instead.
Re: Imi wa desu ka
Hmmm...
Yes, I certainly do feel the goal posts move - and it is one of the supreme frustrations of participating in this group.
dhaen said:Surely the "issue" is whether each one of us would find them useful.
ie what's the capacitance...
Hmmm...
Please tell us more, any particular configuration that works for you?
Cheers
Joel,
OK, I stand corrected.
But that's really just the first item in the "how it will behave" list, (after the inductance of course).
Yes, we all suffer the frustrations of making others understand our points and vice versa. But we all have the choice of participation.
Now what I do think, is that don't get something for nothing.
More expensive models have the chance of being better, though how much better is so diffficult to determine.
You know, there are 2 kinds of people, sweeping generalisation coming up:
Having a car that likes 98 octane fuel, there are those that put in 97, and those that put in 99 octane. (They didn't sell 98 octane at the time).
I used to put in 99 octane.
What would you have done?
I've tried a few over the years, but I really like <a href="http://home.pacifier.com/~gpimm/">Gary Pimm's designs</a>. Currently I'm experimenting with his BBMCCS in a linestage and have used the 6BQ5 active plateload with excellent results. My "mule" poweramp where I try out things has some of these plateloads, and some larger CCS to try as well.slowmotion said:Please tell us more, any particular configuration that works for you?
If you're interested in trying these types of circuits, I'd suggest Gary's as a good place to start. They are very well thought out, and there are measurements to back them up. GP is a Tektronics engineer.
Good luck, and if you do try them, I'd be interested to hear of your experiences.
Cheers
Well, before you consider the cheaper choke to be the lower octane version, I would like to see some valid comparison done on the few specs that are available. I was quite clearly told that this will make a disastrous plate choke. Yet, there are no numbers given to support that statement. I think that's odd, isn't it? It seemed like such a sure statement.
Because you must face the reality that maybe the difference in price has less to do with fidelity, and more to do with market determined factors, eh?
Joel said:Because you must face the reality that maybe the difference in price has less to do with fidelity, and more to do with market determined factors, eh?
I'm really starting to like you Joel
Tim
Re: ...lets have a group huddle...
Excellent James! I'm glad we finally got a second opinion.
James D. said:Just got mine on Saturday...Tried it in my ecl82 se amp on the driver triode and it rocks!!!
Great little plate choke
Hunh? The only silicon in the 6BQ5 plate load is a 431 to set a stable bias and a protection diode.slowmotion said:Thanks Brett,
I know, GP's designs probably work very well,
even tho they are full of transistors
I was thinking of something with valves ,
much more interesting
I find the abhorence of silicon in <i>any</i> application amusing. Properly applied it can make a better circuit, if you use the benefits of the sand.
They're not exactly expensive on parts, so why not try them, and make up your mind for yourself.
Brett,
I actually agree with you, I just think valves are more fun
and much better looking
I find the abhorence of silicon in any application amusing. Properly applied it can make a better circuit, if you use the benefits of the sand.
Choked
Tony,
I asked my engineers at work to measure one for me...Not sure I believe the result as it quite good, although it is inline with Joel's result... I'll ask them to show me how they measured it later.
Results :
Inductance: 143H
Resistance: 3860R
Capacitance: 78pF.
I'm using them as plate and grid chokes in an ECL82 SE amp. Before it was a standard plate resistor and capacitor coupled design. It opened up the sound and made the bass more tuneful - maybe a bit deeper as well.
hope this helps
James
Tony,
Results :
Inductance: 143H
Resistance: 3860R
Capacitance: 78pF.
hope this helps
James
Hmmm...
1 / (2 pi sqrt[FC]) shows resonance at about 1.5kHz if I worked the Windows calculator right... Of course, this is an impedance of some 650k, or should I say infinity, since it's parallel resonant (I presume). So any triode will more than well damp it, and even a pentode (such as 6AQ5) would get away with it well I bet.
An impedance vs. frequency graph would sure be nice, since parallel capacitance tells us nothing of HF performance, where the inductance is series resonant (low impedance) with the interwinding capacitance.
Otherwise, it does sound nice!
Tim
Tim
- Tubes / Valves
- good sound with cheapo chokes
