Good Case for simple chip-amps
I posted a link to a promising case now available in the US, I have one now and here are the details.
It isn't quite what I thought, but it is a decent case, especially forr $22 US (including shipping). This one's black, smooth finish inside & uniformly rough (sandblasted) finish outside.
The case has ribs inside, on the top & bottom surfaces. The case is 2 mm thick and the ribs are 1.5 to 2 mm tall.
The minimum inside dimensions are: 61.5 mm tall (between the ribs), 133 mm wide (at the center joint), the usable width of the top and bottom surfaces 127 mm, and 200 mm long.
If it looks a little "pinched-in" at the side joints, that's because it is, by about 2 mm.
http://cgi.ebay.com/Aluminum-Projec...main_0?hash=item250323035406#ebayphotohosting
