Hy all ,
My intention is to build my own amplifier that would be rated between 200 and 300W. I also want to be able to connect it directly to a laptop or computer sound card without additional preamplifiers.
If any of you has a project that is functional and really hyfi that worths building, please let me know.
Kind regards ,
Eugen
Kind regards ,
Eugen
300W
Did someone built thid amp?
http://www.horksblog.com/audio/300-watt-mosfet-real-hi-fi-power-amplifier.html
What is your opinion.
Thank you.
Thank you.
correction
It looks like it would work, but at low power.. it must be
one of Nico's early ones..
Bc556 /Bd 140's are low voltage devices and best suited for
baby amps (50W). I really dont see where it could do 300W???
To add current mirrors/CCS and approach a more standard
"blameless" topology makes for a more reliable , foolproof design
with not much added complexity...better devices would assure
that there would be no fire as well. 2SC1845(LPT),
MJE340-50 or 2sa1381-2Sc3503 (VAS) would make
for a real high voltage, properly derated project.
Look in my :
http://71.203.210.93/pdf1/Electronics/Projects/Audio_amp/
Built some of them , simulated all of them,, amps from Quasi,
Jagodic,leach , mine (frugalamp), DX.. all sorted by
type and power output. Happy reading.
OS
reply
AndrewT , ostripper
Thank you for your replies.
I will use 300W speakers 4 ohm that are produced here in Romania. I do not know much about them. All i know that they are very heavy monsters with a big magnet.
The fact i am asking you for a good amp is because i have experience only in digital hardware. My experience in analog is minimal. I still could use my skills to build my own PCB-s in Altium Designer as i do with my embedded boards.
Why i am telling you all this because it will help me a lot to have a project that has a list of components with all the features (power , resistance , package of the transistors etc..). I found a lot of projects that have only a electric schematic , and that is not enough for me.
please give me a link if you have available.
Thank you once again.
Eugen
AndrewT , ostripper
Eugen
power amplifier
hi nbcd
greetings making a good amplifier is rare try dx tubo easy to
assemble cheap no regrets made one with 9 output pairs tested in
2 ohm load did not give up go for it use st make output transistors
no fakes less than 2$ a pair practically tried amplifier bye
thanking you
andrew lebon
hi nbcd
thanking you
andrew lebon
Re: schematic
go for one of quasis nmos series
http://www.adam.com.au/cgpap/QuasiWeb/index.htm
nbcd said:hello andrew ,
Do you have some schematics?
Best regards ,
Eugen
- good amp project needed
