The closest part that I know is this
http://export.farnell.com/marathon-...rminal-block-3position/dp/1427835?Ntt=1427835
It's however not gold-plated. Maybe you find a partnumber for a gold-plated version in its datasheet.
Have fun, Hannes
Have fun, Hannes
Hi!
Could somebody tell me where can I buy such a Gold-Plated Screw Terminals
for PCB mounting like one is on the attached picture?
Greets:
Tyimo
These are typically used in car audio installations - maybe that gives you a lead.
jd
Yes I know, but I still not find anything, except Monacor.These are typically used in car audio installations - maybe that gives you a lead.
jd
I don't know that the car audio and Xover makers where buy this parts.
Tyimo
Tyimo
Hmmm. You know, here in Europe you often find them in large electronics dealers like Mediamarket.
That's where I saw them once, other than that I can't suggest anything else. Can you not buy them from Monacor?
jd
Maybe it helps if you do a search for : gold-plated barrier strip
Ecco, took me 5 seconds => http://www.thefind.com/instruments/info-barrier-strip
jd
I can buy from Monacor but theirs price is a bit overpriced...
Great site! I didn't know it yet.Maybe it helps if you do a search for : gold-plated barrier strip
Thanks. Unfortunately those are not for PCB mounting.
GMAFB, 10 seconds => http://www1.futureelectronics.com/doc/WECO/983-W__04.pdf
Thank you!
I think the problem was that I didn't know the right name of this type of connectors: Screw and Tab Connectors for Printed Circuit Boards
Tyimo
- Design & Build
- Parts
- Gold-Plated Screw Terminals
