I'm guessing the veneer is actually vinyl, as most furniture board is? I know for sure the wood glue I use will not stick to any plastics or metals, that's EvoStick glue, some may be more tolerant. If it's real wood veneer it will stick, but it may compromise the integrity of the joint glueing to such a thin piece of material. Removing a strip to glue MDF to MDF is a sure way to get a good joint in this instance
I'd agree.
I'd remove the vener just to be safe anyways. I'm sure an exacto knife would do the trick.
