Ghettoblaster help
First a little background
This is an old samsonite briefcase
inside it has a Sure 11141-112v100 (2x 100 watt) amp
a battery
2 polk db401
2 polk mm651
1 old pioneer horn that while connected is mostly for looks
a few relavant pics (too large to attach)
https://dl.dropbox.com/u/508467/ghettoblaster/boom1.jpg
https://dl.dropbox.com/u/508467/ghettoblaster/boom2.jpg
https://dl.dropbox.com/u/508467/ghettoblaster/boom3.jpg
I have run into a couple issues recently and I am not sure what the problem is...
1) should the cooling fan on the amp be always on? or is it temperature controlled? It does not seem to run at all on mine (maybe the root of my issues?)
2) I notice that over time while it plays it gets quieter but if you bump it a bit the volume picks back up. Initially i thought this could be a battery problem but I had it at the beach the other day and a little bump would crank the volume right back up which wouldnt make sense if the battery was out of charge?
Any ideas about this would be much appreciated
Thanks!
a battery
2 polk db401
2 polk mm651
Thanks!
ok so it has been running pretty well but the other day i noticed a a really high pitched whine / distortion coming out of the tweeters this happened before when I was using it outside a a thunder storm came through turned it off for a bit and it was gone.....but the other night it seemed to stick around through a few power cycles...
Any ideas?
Any ideas?
