Jan,
nevertheless you care about some hardly mastered distortions utilizing dubious and harmful cancellation technique. You have much time to waste.
Necessarily, it is, would be extremely bizarre if it was not.I think you may have fallen victim to the notion that 'the output cap is part of the audio circuit'.
Right, the rectifiers are especially subversive.The audio signal current also goes through the rectifiers and the xformer.
Lumba Ogir said:Jan,
Well, I can give you the info , but I can't force you to think.
I respect your believe. Best of luck,
Jan Didden
PMA,
Power supply capacitors are in the signal path, one of their purpose is to provide an adequate signal ground and isolation between stages. The function and impact can be demonstrated mathematically (using Thévenin's theorem is suitable), or something simpler, by listening test, replacing the capacitors with another type gives a convincing manifestation.PSU filter caps are not directly in series with signal output; again oversimplification of unqualified amateurs. Give a series resistor of 100 ohm into collector power supply branch of an emitter follower. How does it come that it has output impedance of some 5 ohm still?
Lumba Ogir said:Power supply capacitors are in the signal path, one of their purpose is to provide an adequate signal ground and isolation between stages. The function and impact can be demonstrated mathematically (using Thévenin's theorem is suitable), or something simpler, by listening test, replacing the capacitors with another type gives a convincing manifestation.
I am always eager to learn something new, so please provide those mathematical calculations (based on Thevenin or whatever other theorems you enjoy). Thank you.
that doesn't sound right.Lumba Ogir said:Power supply capacitors................. one of their purpose is to provide an adequate signal ground
PMA,
that capacitor is not infinitely large, its impedance is not zero and changes with frequency, making gain and phase vary, its dielectric absorption and dissipation factor is very typically 4000 times higher than that of polypropylene, add inductance, resonance and so on. This will not give a perfect signal ground, count on dispiriting results even with the most esoteric brands and types. Sonically it means grunge, lack of detail, a smeared and turbid sound. You should at least try to ease your reliance on that blunt-witted toy.
Lumba Ogir said:PMA,
Ok, can we get to the math now?
PMA said:Emitter follower = 100% voltage feedback
No need to restrict one's self to linear emitter/source degeneration. The N/P channel JFET input pair is also 100% negative feedback.
I only say, if it sounds better to you (forget the ''others'' this is not LOST season 5), keep it. If you wanna research what and why, well, get 12 scientists in an expensive lab and fund them for 5 years.
Inventing theories is a psychological need, but it can turn in to crude snake oil in the marketing's hands.
PMA and salas,
would you kindly present a truly scientific audio signal circuit model including the power supply capacitor, please.
What did you qualifiedly mean by "not directly in series with signal output"? Are they directly in parallel?PSU filter caps are not directly in series with signal output; again oversimplification of unqualified amateurs.
Lumba Ogir said:PMA and salas,
My comment wasn't directed to you. Its my approach towards subjective VS objective. I do think that I listen to PSU caps clearly too. Especially in unregulated power amp PSUs. But I am not qualified to know why, so I just keep whatever sounds good to me. And if its an illusion, well its a repeatable one to me, so its part of the experience. Fair enough for me. But I think that Syn08 and PMA know their stuff. If they don't know why, I will still hear them caps, but I can't know better than such learned DIY audio members. Off course if I had products out, I would be asked to say why I use this and that to my customers in a ''scientific way'' so I could impress them. If I did not, my marketing would scold me. And if I did, guys like PMA and Syn08 would lough at me by all rights. And since far too many people read brochures than the Solid State section of our forum, I am inclined to believe that far too many urban myths have turned in to standard ''knowledge'' out there. It happens in all walks of life. Social distortion & propaganda. Makes the economic world go round, alas in a non ideal way.
salas,
I have much to say on that matter, maybe later.
It`s all right.My comment wasn't directed to you.
- General purpose shunt regulator
