I want to get rid of some of my DIY audio stuff, so I'm having a garage sale.
Garage sale Inventory:
Semi finished projects:
6 x Leach amp clone with 6 transistor output mounted on heatsink (Output stage not mounted yet)
2 x Leach amp clone with 10 transistor output mounted on heatsink (Everything is working on these two, just add power )
Spare PCBs:
4 Leach amp clone PCBs for 6 transistor output (2.4mm 95µm (2.5OZ) CU)
4 Leach amp clone PCBs for 10 transistor output (2.4mm 95µm (2.5OZ) CU)
18 PCBs for discrete power supply (DIY audio project)
10 PCBs for active filter (DIY audio project)
Electrolytic capacitors:
150 x 10.000µF 63V snap in, 10 mm pin spacing, 35 mm in diameter
20 x 10.000µF 100V snap in, 10 mm pin spacing, 40 mm in diameter
+ Tons of other types
Mica capacitors 500V 7.2mm pitch
10pF, 33pF, 39pF, 47pF, 180pF, 390pF
Spare semiconductors:
50 x MJL1302/3281
50 x MJL4302/4281
25 x MJL21193/21194
25 x MJL21195/21196
MJL15030/31/32/33
MJE340/350
BD139/140
2SC2240/2SA940
MPSA42/92
1000 x BC546C/556C
45 x OPA2134
+ Various others in RAACO system
+ High power rectifier bridges (25A 600V)
A few of the semis are samples that you will get for free, the rest are bought from various shops!
Transformers:
1 x Torrid 1000VA, 2 x 55VAC secondary windings, 240V primary winding
2 x Torrid 500VA, 2 x 40VAC secondary windings, 240V primary winding
4 x Torrid 50VA, 2 x 15VAC secondary windings, 240V primary winding
2 x Torrid 750VA, 2 x 40VAC centre tapped (For stereo amp), 240V primary winding (Used B&O transformer)
Heat sinks, and other stuff:
Various PCB mounted
2 x 7kg heat sinks used for my Leach amp prototypes still has 4 working amps on board.
Notes:
All this has to go, so give me an offer
I will only sell the whole thing together, so please don’t ask for specific items!
I will not ship this stuff, so if anyone is in my neighbourhood and want this stuff, drop me an email with an offer!
\Jens
Spare PCBs:
50 x MJL1302/3281
50 x MJL4302/4281
25 x MJL21193/21194
25 x MJL21195/21196
MJL15030/31/32/33
MJE340/350
BD139/140
2SC2240/2SA940
MPSA42/92
1000 x BC546C/556C
45 x OPA2134
Transformers:
Various PCB mounted
Notes:
\Jens
Garage sale update
Garage sale Inventory update:
2 x Active filter one boads with sockets for all opamps mounted.
Spare PCBs:
50 x MJL1302/3281
50 x MJL4302/4281
25 x MJL21193/21194
25 x MJL21195/21196
MJL15030/31/32/33
MJE340/350
BD139/140
2SC2240/2SA940
MPSA42/92
1000 x BC546C/556C
45 x OPA2134
+ Various others - ask
Transformers:
Various PCB mounted
Notes:
\Jens
Spare PCBs:
50 x MJL1302/3281
50 x MJL4302/4281
25 x MJL21193/21194
25 x MJL21195/21196
MJL15030/31/32/33
MJE340/350
BD139/140
2SC2240/2SA940
MPSA42/92
1000 x BC546C/556C
45 x OPA2134
Transformers:
Various PCB mounted
Notes:
\Jens
Garage sale update
Spare PCBs:
+ Tons of other types ask
Mica capacitors all gone
20 x MJL21193/21194
MJE340/350
BD139/140
MPSA42/92
Transformers:
Various PCB mounted
\Jens
Spare PCBs:
20 x MJL21193/21194
MJE340/350
BD139/140
MPSA42/92
Transformers:
Various PCB mounted
\Jens
Re: Hi Jens
No not at the moment - sorry
I will let you know if I come across some.
\Jens
Flodstroem said:Do you have any "Computer Grade" capacitors (=screw terminals) for sale?
If yes, Capacitans value, Working Voltage and types?
Is it possible for you to make a list if you have different brands?
Thanks in advance
\Jens
Garage sale update
Originally posted by JensRasmussen
Hi all, this is what I have left....
Spare PCBs:
Transformers:
Various PCB mounted
\Jens
Spare PCBs:
Transformers:
Various PCB mounted
\Jens
Re: Garage sale update
How much for these? PM or email me at Doug.Dale @ Gmail dot com.
JensRasmussen said:Originally posted by JensRasmussen
\Jens
