Hi All
Been awhile since I've looked at single driver solutions. I built my first speaker about 11 years ago - started with FE164's in folded MLTLs and ended up with a massive 4-way active OB consisting of eight 12's, two 10's, two 7's, and a CD WG (ala Geddes) per side. Loved the last system, but it got to be just too freaking big. Anyway, I boxed it all up, enjoyed the freed up space, and settled into a pair of Skull Candy headphones and iTunes for a couple of years. I knew it wouldn't last. I've been revisiting the idea of simplicity and not-too-large enclosures, although it's easier for me to go up than out, and the BIB seems like what I need to look into. I gotta have 40Hz but I don't need alot of volume as these will be in a small (~12' X 15') room with usable corners.
I literally had forgotten I had them, but I dug out a pair of FX200s that I would like to utilize in a BIB along with a Fountek NeoCD3 ribbon for reinforcing the highs if needed. I'll biamp with an active XO if the tweeter seems to help - I doubt that I can hear anything over 8K anymore anyway.
So now the question - is an FX200 doable in a BIB? Is its high-ish Qts a drawback? I can't seem to locate the BIB Calculator but I did shoot Godzilla an email.
Thanks for any suggestions.
Allan
Allan
Happy Holidaze and all that jive!
Backup location: http://www.diyaudio.com/forums/atta...90303-fostex-fe206e-bib-bib_166_gm_v2.xls.zip
Its published Qts is still in the ~optimum range, but combined with its Fs, Vas, it calculates a very large cab, so you'll have to fiddle with the inputs to get to a size you can tolerate and of course the deep bass will be rolled off as the trade-off.
GM
GM
Thanks GM! And a Merry Christmas to you too.
Yeah, it's gonna be a big cab at roughly 26 X 19 (external) and about 90 inches tall. I remember the MLTL I had them in was quite large as well, but the in-room extension was pretty remarkable. A slightly smaller footprint might still give some decent results. I'm game.
Allan
Allan
Thanks again GM. Got the Explorer from MJK's site. Good call on the modifiable terminus - that'll give me some options.
Applying a ~10% rule to the TS parameters in the calculator and keeping Sm at about .85 of the original (halfway between your .7 recommendation for minimum), I'm thinking a 168 inch line (84 inches tall), and a 22.5 X 16 internal would be a place to start. From all the reports I'm reading, these things apparently have some leeway so a half an inch here and there probably won't be audible anyway.
Allan
Allan
You're welcome!
Yes, I designed in enough to either account for some T/S specs variance and/or downsize a bit and/or have an adequate amount of acoustic efficiency to allow in room tuning via increasing stuffing density.
Factor in some room gain beyond half space and in theory you may need significant damping for it not to sound bass 'heavy' in smaller rooms and/or with higher Qts drivers, but it's always better to attenuate than boost or worse, have nothing to boost.
GM
GM
Sounds like a plan AJ! Sorry I've been away for quite a while due to a messy divorce, grrr! Thanks for posting the BIB calculator GM!
Zilla
Zilla
Thanks Zilla. Sorry to hear about the divorce man - been there, done that.
After reading that entire monster thread on BIB's (do we get an award for finishing it in a single day?), I'm starting to think a little smaller and I'm looking at the F16x Fostex lineup. The depth of the cabs for the FX200 is a little more than I want to deal with. I still like the extra space I've been enjoying lately and I really just need 40 hz, which this room gets pretty readily with the right placement.
I'm really interested in the Spawn too...lotsa choices.
Allan
Allan
O how lucky can one man be? I wish I would find some FX200 lying around in my cellar...
Do you know Craig Schmidt's "Holy Grail" with the FX200 drivers?
Single Driver Website
Bummer, any end in sight? Hope the kids are holding up OK.
No problemo!
GM
- Full Range
- FX200 in a BIB?
