Funniest snake oil theories
It can make a significant change to the sub-100Hz FR of the speakers. I would not recommend it for passive speakers, but for actives it seems a valid tuning method. Rod Elliot uses it. But I don't want to open the currentdrive can of worms on here :)
Active is a completely different game. In a previous live I did some calculations
on the artificial change of the TS parameters after Stal (with a little circle above the a,
I cannot create that on my keyboard). That involved negative amplifier output
impedance to compensate the ohmic resistance of the coil. I gave up when I noticed
that the ohmic resistance is a moving target that changes MUCH depending on the
history of applied power.
That was in 8080 technology times. With current DSP processing one could
measure that in real time and try it again.
PS
And a 8 Ohm voice coil has usually +/- 4 Ohm resistance. Compare that
to a somewhat decent cable.
Sufficiently good isolation will be provided by any competent PSU.
So, what is a "competent PSU ?.
As I often say, cable sensitivity is a sign of poor electronic design.
Power cable sensitivity ?....what is such "poor electronic design" ?.
Of course, with a Class B or Class D amplifier the mains current draw will vary with the music envelope but no amount of fancy cables will change that.
The final power cord from the source power (wall socket/power strip) will have variable LCR values (and other parasitic values) according to materials and construction....it is to be expected that these values will interact with the primary circuit, and through reflection the secondary circuit and according to reactivity/damping of both these two circuits.
Any non ideal cable will vary the instantaneous voltage, current and phase values according to changing current demand for a non resistive load.
All these reactive load parameters will set up excitations that may pass audibly through to the speakers.
Dan.
Monster Cable was one of my earlier venture into the cable changing game. For interconnects, they advertised the skin effects at various frequencies and used litz wire of three gauges to tackle the problem. Now that I think of it, you only need one single gauge and single conductor since the gauge would limit the maximum skin depth anyway while the current load is very low.
If you just consider the transformer, the rectifier, and the filtering caps, I wonder what other design options you have?
You seem to be a part swapper. There are also inductors and resistors and various ways to build various linear or shunt regulators.
There are also ways to build really good filters without capacitors.
Starting with a transformer there are different impedances and DC resistances of the windings to consider. You can choose to use full wave or bridge rectification. You can use choke input or capacitor input filters, heck even an inductor on the transformer primary works!
When we are beyond the grade school level actual design can happen and interaction of the chosen transformer values with the chosen diodes can be optimized. Then we can look at the time constants of the filter stages and check what our dominant poles are. Check the power supply impedance against frequency. And it goes on and on.
So much about "just ... the transformer, the rectifier, and the filtering caps"
:cheers:
Have you looked at the CSD and distortion as well?
Good point. Here are the harmonic distortion plots. What is "CSD"?
