full range pics-
exact at auction-
http://64.233.179.104/translate_c?h...ist3,auctions&hl=en&client=safari&rls=en&sa=G
xlated text-
Long and others also exhibition of the [ekuzakuto] product with deko_mamily which your [ku] patronage it receives to end with this, because in the future it takes over to the exhibition with st47jp, please add st47jp to alert by all means.
Since being announced in 1974, present up-to-date product mu: Until xacta-16 the constant basic design.
From analog age over digital age, the immortal masterpiece unit 5150C which continues to be regularly used in many supporters.
This time, it is exhibition of brand-new unused stereo pair after a long time 5150C dual contact 1981 make.
It is appearance of masterpiece full range unit 5150C/Dual of [ekuzakuto] of 1974 1st period.
Furthermore this unit even presently, it is the superb article which acquires the appraisal which does not shake 'as the full range unit which plays the most beautiful sound in the world where it exists' between the Japanese and Europe and America veteran audiophiles.
Well, please view! The unit which had the appearance of this black nickel finish this time exhibits, it is the brand-new unused sequence number stereo pair of 5150C/Dual.
5150C/Dual 'does not pull at all,' the tune which nothing adds is actualized, all software is reproduced to your listening room without failure.
As for the tune 'the raw' very thing. It seems that is exaggerated, but the sound where this comes out of the unit 1, even when trying hearing, seeing, trying verifying you cannot agree upon,… is BASIC unit of [ekuzakuto] which always offers such surprise.
The warm knowledge new this unit which goes quite at area, audio to come well, the fragrance of age that way, can be called the immense range which surpasses the up-to-date all speaker and quite the valuable unit which flaunts resolution and the linearity.
Simple is Best! And it is the superb article which is not with the high end veteran people who feel keenly necessity of very can have enough the pleasure of point luxurious principle sufficiently valuable existence and starting point revolution and.
First first as for all sizes of size the one which forgets completely is good, probably will be. (Very is not sound of 16 centimeter unit, in the spatial capacity which of course, is limited, all high-end speaker systems are surpassed have fearful performance)
The tune when you are proud of preponderant resolution and instantaneous power, audible zone over entirely beauty of supremacy is adjusted simultaneously with minute sound field description and [ririkaru] and at the same time double layer it has drug charm has.
All music genres, including feelings a little by comparison with the accurate unequaled character of 5150RM which forms the knitting machine and the two great authorities, 'with the character' 'like Actress' performer in a certain sense, there is a personality which it reappears.
The feature of 5150C/Dual
Voice coil diameter: 26mm?
Playback frequency zone: 30 - 20,000Hz±5db (at the time of EL control 3205C load and 4037 enclosure use)
Sensitivity: 92db/w/1m
Resistance input: 10W rms 20W peak
99.9% electrolytic pure iron you bend and magnetic permeability of 100 times or more you have high flux density with using the yoke just by processing by comparison with the former rectangular yoke.
The revision for the instantaneous magnetic flux change when operating full circuit of the alnico magnet whose height is high with covering with the thick copper ring, is done accurately, when the demagnetization phenomenon which is fault of the alnico magnet almost is designated as zero instantaneous power of vibrating type more is made simultaneously firmer.
Mass of vibrating type below 3.2g and is light very, high speed has the response.
In order for you to use better than the ??????????????? the ???????????????
- With the EXACT unique hypothetical acoustic image that as for this unit from 6 ? favorite with music, the room of 12 ? the tune which is not defeated to all large-sized systems and, 'there it stays', it will bury we would like the unit which is optimum to the one which you think that to exhaust, it will be able to say.
And element clear it did in the owner and it was the [ku] minute and through the tune which it will be refreshing and at the same time the [ku] being destructive, had preponderant permeability, the thrilling experience and full it probably is to offer the stomach impression, and the functional beauty which sound engenders above expecting.
This time the technical manual (the Japanese edition) with we attach the plan of general-purpose enclosure 4037 type to the dual contact version brand-new sequence number stereo pair of 5150C/Dual.
The original work of the box is OK now.
To complete ?5150C in 1974, to evolve as usual one voice coil type to 1979, because it was the unit which receives high appraisal from the internal studio as a recording monitor, there is no accessory basically, very excellent performance is shown.
But, because the differential drive system due to the voice coil of the twins (dual contact voice coil) with it is to be an element clear forcing function which is said, the fact that this is not utilized is at all wasted meaning.
As a proverb whether or not the appropriateness as for you do not understand, but, the basic kind of evolution which from the equivalent diode of a triode develops into the triode exists there, very various uses only of the dual contact open.
- To jointly use the various accessories, efficiency is made to match to wide needs, because it is the unique system speaker in the world, the backup part being many major feature of [ekuzakuto]. And, also the original work of the accessory in order to designate a better tune as the hand being possible, as for the especially enclosure from the plan you arranging by your, the one which it produces is becomes well enough and with. (Just the part of the zoom port the person who uses the original part is good, probably will be)
In addition, because helping in order to remove best tune at the home has gone in the very wide range if you utilize these, most being cheaply shortest, also it is possible to designate the tune of astonishment as the hand.
- In any case, that it can enjoy to many times with the originality device, it has those where with the 5150C/Dual dual contact, in addition basic efficiency it answers that sufficiently and quite is superior.
Also ?5150C/Dual in case of the new item, following to the tradition of [ekuzakuto], first 1,000 hours aging is necessary. And identity being even excessively candid, it has the resolution which it will be refreshing and because the [ku], in addition the high speed impression is high, it probably means that sound of surprise heaven dynamic area wraps you from the one-shot eye.
If volume and the power impression of being abundant, sufficiently the playback range over, it drives with adjustment, about it drives in tune of high dimension without the limit to change, there are no times which with adjustment circumstance of the listening room become the impressive form even to the acoustic image, grow tired.
- Details and the like of customization and unit, as for the one which we would like you to know in detail 'in regard to entry please ask mail address to the question column'.
We answer directly.
In addition, because valuable user voice of the people of the user which past can be started using in 5 years (update 06/06/30) and we send the data of the thing which would like to become, knowing such as criticism in the foreign country, in this case 'in regard to entry please claim mail address to the question column'.
There are no times when of course, your address is released. Also the one which is claimed already please.
- Because it can get near to the tune which is made use environment and ideal of the one which is bid successfully even at the one step, servicing customization job before the shipping, to stay, because the [ri] it increases, please utilize by all means.
Cost does not catch of course altogether. In addition the time when it is necessary for customization in case of 5150C/Dual, usually is 120 hours from 96 hours.
It is large welcome with any kind of question. Until agreement it goes, please ask.
- As for bid of the one whose appraisal is bad please be modest. Depending upon when when it deletes, because it is, badness please do and do not drive and acknowledge.
It is new one large welcome.
To the person who your ??????????????? audition is desired the ???????????????
When the audition of EXACT unit it is desired, please add in writing the effect and mail address in question viewing.
The audition room there to be Saitama prefecture Misato city, because from Osaka and Niigata, or you have crossed over even from the foreign country, as for traffic possible one 'perhaps hundred sentences whether in one listening ? the [zu]'. In addition, and it is possible in the Satoshi optical hall of Shizuoka prefecture Fujieda city, to mention the tune of the 5150RM/regular, it is possible to mention the tune of 12cm unit of the ? ball in Kagoshima prefecture Kagoshima city.
Love listening carrying LP CD, please experience the tune of the surprise. (In Kagoshima as for LP the audition it is not possible) without modesty please.
Then, please participate pleasantly.
mu: xacta muxacta EXACT SOUND GRAPHIC is registered trade mark of [ekuzakutosaundogurahuitsuku].
the madness of 'copy and paste'
13272
Maruo acoustic full range speaker unit brand-new pair is exhibited. As for this unit with very unusual unit, the cone paper of the damper and the tannin persimmon attachment which it is possible with Bakelite. As for the edge, as for the chamois and magnetism it is magnetism and charm full unit inside the alnico. Timbre, it seems that [kuratsushitsuku] is proud. Simply, after the purchasing, because is just under of verifying where sound comes out you cannot say at all. Inspecting with [netsute], very, there is no article. How is in the audio collection? We ask with NC/NR.
same manufacture as these?
http://www.diyaudio.com/forums/showthread.php?postid=1142994#post1142994
jbl d130
ev
altec
14608
yamaha ja2071-
ev/wolverine-
ev
more jbl
northern electric
pioneer pim8l
euro field coil-RFT-
14619
CTS-
altec 400b/400x-16
4' ampex
jbl 260 for ampex-
altec 405a-
405 8-h
altec 756b
14818
