FS: Zen v1 board, stuffed.
The components are: Fets are IRF's, (as they should be), all resistors are metalfilm, mostly Phillips/Vishay. PSU elctrolytics are Nippon Chemicon, psu bypass and input caps are Black Gates. The output electrolytics are bypassed with Panasonic filmcaps, (underneath the board). The amp sounds pretty good;)
Steen:)
Ps. As you can see everything is still soldered to the board.
