FS: TPA3251 TPA3255 2.0 BTL Amplifier
For sale is one of my TPA3255 amplifiers. It is meant for 6-8R speakers (works with 4R as well) at up to 48V. All components are brand name stuff from known vendors, distributors. Input caps are WIMA MKS2, potentiometer is Alpha. Case is lasercut from 3mm acrylic glas.
At normal listening levels the fan can be omitted. Depending on supply voltage and output power.
Inputs are RCA and 3.5mm jack, outputs are Phoenix 12A connectors, plugs are included.
attachment.php
attachment.php
attachment.php
- Case is the gray one
- Pot knob is red - not black
- RCA housing is black - not red
- 3.5mm jack is upgraded to a pro modell
Price: 155€ + shipping worldwide.
Regards,
doc
TPA3255
Hi Doc;
I have been monitoring the exchanges regarding this chip
I have been deliberating the EVM from Mouser over this last week
What Power Supply have you found to be the best match with the 3255?
I may forgo the EVM and ask Santa to pm you for your payment details - instead of fannying about trying to put the EVM together with Inputs/Outputs etc, etc
I'm in the UK
Owen
Cheers mate,
to be honest, i actually use the 3255 with a 200W boost-converter from a 12V SLA, as these are running on my bike PA. This works presumably well, even if you push them a bit. At home, i use them together with a 38V self resonant ZVS SPMS (300W max).
If you want to use them at home, a 48V Mean-well supply will do the job. (300W+) In the 300W class, there are fanless models available. If you use them with only 4R speakers, you may go down with the supply voltage. (36V still put out a good amount of "ompf")
Regards,
doc
For sale are two tiny TPA3251 amplifiers.
First one (2/2 build):
Price is 150€ + shipping worldwide.
Second one (1/1 build):
Price is 190€ + shipping worldwide.
Also for sale is one TPA3251 "modell blue" from the testbench which has some mods attached to the AFE.
Price is 110€ + shipping worldwide.
And lastly a TPA3255 in the same style. Price is 140€ + shipping worldwide.
Regards,
Christian
