John - I sent you an email.
Those pictures that don't show up were wiped from a web server that I no longer have access to. If you want to see where the parts go check out the photos attached to posts 12 and 13. They show the silk screen layer pretty clearly. The part designators have changed but it shoudln't be too hard to figure out which parts go where.
imix and IndyAudi - your boards were sent out on Tuesday
Here's an updated list.
VIN, GND, VOUT connections: up to 18ga wire
C1: 0.3in (7.5mm) lead spacing, radial electrolytic
C2: 0.2in (5mm) lead spacing, radial electrolytic
C3: 0.1in (2.5mm) lead spacing, radial electrolytic
C4: 0.3in or 0.4in (7.5mm or 10mm) lead spacing, axial ceramic or radial polyester/polypropylene
C5: 0.3in or 0.4in (7.5mm or 10mm) lead spacing, axial ceramic or radial polyester/polypropylene
R1: standard 1/4W axial lead resistor
R2: 0.1in (2.5mm) lead spacing, cermet potentiometer
IC1: 3-pin TO-220 voltage regulator
Very high quality boards Brian,they even exceed my expectations by a fair margin.
IndyAudi - glad to hear they arrived safe and sound and that they're better than you expected
gilid - There is one person who wanted a board but hasn't written back to me about payment. I will contact them and if they don't reply within a couple days I will offer it to you.
Arne - your board is in the mail.
Everyone who ordered boards should either have them by now or they're on their way to you because I'll be sending out the last one today.
gilid - I'm sorry to inform you that they're all sold. If I use up all the ones that I have chances are good that I'll have some more made in the future. I'll try to remember to send you an email if/when that happens.
Thanks everyone.
Thanks everyone.
Originally posted by BWRX 'Thanks again everyone'
Brian,
It is we,the fortunate recipients of these clearly superior boards who are indebted to you.
