FS: T-REG (TUBE VOLTAGE REGULATOR - POPULATED BOARD))
SOLD: T-REG (TUBE VOLTAGE REGULATOR - POPULATED BOARD))
For sale is a T-reg tube voltage regulator populated board.
I used almost all Alen bradley resistors. The board is set for a single 6as7 or 6080 voltage regulator tube.
More info about the regulator you can find here:http://www.linearaudio.nl/t-reg-1.htm
I am located in EU.
Shipping worldwide.
Please post your offers if interested.
I just found out, that I have two boards. One is complete populated and has also two PIO big russian 4,7uF caps included.
The nr.2 is also populated but was a experimenting board, a bridge rectifire is missing and also the two 4.7uF caps.
The shipping costs to Spain is around 6-10EUR priority, normal 4-6EUR (more risky)
T-reg does not operate from AC. It needs first of all a smooth DC,
for example a LC or RC filter before you can feed it to the regulator.
If you for example need 250V DC you need to have around 290-300V DC before feed to
reg.
The best would be if you could tell me more about your psu. What are the sec. of the power transformer and .....
