$10.00 each. More available.
NOS Sprague Vishay 632P106X5050 Metalized Polycarbonate film capacitors. 10uf 50 volt 5% tolerance. These were made to incredibly high standards for military aircraft. They are discontinued due to the world wide shortage of Metalized polycarbonate film. They retail for $312.00 each. They are excellent as coupling capacitors or used in speaker crossovers. I'll try to answer any questions you may have. I can email the manufacturers data sheet.
Size: .48" circumference X 1.31" long.
FEATURES
• Superior performance • High efficiency • High stability • High reliability • Rugged construction • Small size
DC Life Test: 140% of rated voltage for 250 hours at + 125°C. No open or short circuits. No visible damage. Maximum Δ CAP ± 5%. Minimum IR = 30% of initial limit. Maximum DF = 0.5%. Humidity Test: 95% relative humidity at + 40°C for 240 hours. No visible damage. Maximum Δ CAP ± 5%. Minimum IR = 50% of initial limit. Maximum DF = 0.5%
PERFORMANCE CHARACTERISTICS
Operating Temperature: - 55°C to + 125°C. Capacitance: 10.0μF Capacitance Tolerance: ± 5% DC Voltage Rating: 50 WVDC AC Voltage Rating: See AC Voltage Rating table. Dissipation Factor: 0.25% maximum. Voltage Test: 200% of rated voltage for 1 minute. Insulation Resistance: At + 25°C: 50,000 Megohm - Microfarads, or 100,000 Megohm minimum. At + 85°C: 2,000 Megohm - Microfarads, or 4000 Megohm minimum. At + 125°C: 250 Megohm - Microfarads or 500 Megohm minimum Vibration Test (Condition D): No mechanical damage. No short, open or intermittent circuits.
PHYSICAL CHARACTERISTICS
Lead Pull: 5 pounds (2.3 kilograms) for one minute. No physical damage. Lead Bend: After three complete consecutive bends, no damage. Marking: Sprague® trademark, type or part number, capacitance and voltage.
FEATURES
