FS: RAKK DAC II (PCM 1794) with upgraded power supply
For sale is a complete RAKK DAC II using the PCM1794 D/A converter. This includes the 12V regulated power supply as provided by K&K Audio with upgraded caps. Has two SPDIF transformers Lundahl LL1572 for complete isolation from your digital source.
Note this is a current output DAC; you will need to use some type of buffered I/V converter in order to drive your amplifier or volume control. I have some Vishay foil resistors you can use for this task, but chances are they won't fit the specifics of your application anyway.
All you get then is the DAC board and power supply board as shown in the picture.
$250 obo.
