Up for sale is a new pair, in original boxes, of the coveted Tang Band W4-1337SD 4" Titanium Drivers. These drivers were recently purchased and will no longer be needed for a project. They have never been used or mounted.
$85 for the pair plus actual shipping from 33434, with your choice of shipping method.
Here's the published specs from PE.
*VCdia: 1" *Znom: 8 ohms *Re: 6.8 ohms *Frequency range: 70-20,000 Hz *Fs: 70 Hz *SPL: 87 dB 1W/1m *Vas: 0.17 cu. ft. *Qms: 1.51 *Qes: 0.49 *Qts: 0.37 *Xmax: 3 mm *Dimensions: Overall diameter 4-15/16", Cutout diameter 3-3/4", Depth 2-7/8".
