FS: Pair of 18sound 15ND930 15" woofers
(2) 18 sound 15ND930 Neodynium woofers available for sale, $200 each. This is the top of the line from 18sound. They are from Yorkville Unity cabinets that I purchased new. If anyone is interested, please PM me. For sale in the US only. Thanks!
dr suad
Power Rating: 500W RMS
Frequency Response: 40
-4.1kHz
Sensitivity: 98db
Impedance: 8 ohms
Voice Coil: 3"
Weight: 10.6 lbs
Thanks to its versatility, the 15ND930 can be used in 2-way compact reflex enclosures with a 1.4" compression driver, in multi-way systems and in high loading sub woofers as small as 70 lt (compact reflex, bandpass and horn loaded configurations). The neodymium magnet assembly assures high flux concentration, low power compression and excellent heat exchange, since the external magnet configuration is considerably more efficient than traditional under-pole magnet topology. This results in high levels of force factor and power handling with an optimum power to weight ratio.
Here are some photos and a distortion/FR plots.
