Hello,
I am selling my B3SE dac output stage.
The stage includes 4x Vishay S102C 336r00 0.01% precision resistors as I/V resistors. It has also a 22nf cap placed in parallel with the resistors acting as a low pass filter. On the output of the transformer I have also the zobel as per lundahl datasheet
The actual configuration looks like this(missing the output zobel from the schematic
Please note that in this configuration only 2 of the 336r resistors are used(the other 2 are soldered on the board but not used).
I have started with something inspired by Joe Rasmussen and after did the above mood. Here you can see a schematic of Joe`s idea(you have all resistors on the board for this schematic, it only needs to change the connections of the resistors) :
And now some photos with the boards and the transformers :
I have managed to do also some thd test at 20hz, 300hz and 1khz. The rms output voltage was 200mv in all the cases and the transformers were connected to the B3SE dac that was generating the signal.
Please note the the B3SE dac mounts above the the output board.
For any other info please send me a message.
I would like to get SOLD for everything without shipping and paypal fees.
