I have two Northlake Engineering model # S71-198 medical grade isolation transformers for sale. They both work but the power switch housing has broken and the switch pushes into the unit. The switch can be easily replaced or possibly epoxy could be used to hold it back together. Each unit will come with two output cords for you to plug your device into. Asking $150 plus shipping. They are very heavy (about 40 LBS) Free delivery in the Columbia SC area.
See here NE Power Cond... for details of the switch issue and pictures of a unit.
Thanks.
Thanks.
Sir How many KVA do you figure???
The label says 120V 12A
