Are you sure about the dimensions 30x50 mm?
Yes
Thanks, I asked because Nichicon KG datasheet says other dimensions http://www.nichicon.co.jp/english/products/pdfs/e-kg.pdf
The datasheet is correct, but you didn`t read it till the end
Check page 4/8 and you will see this:
are these better used as power supply cap or coupling?
Normally they are used as PSU capacitor, but...where would you use it for coupling?
no specific project for the moment but maybe at the output of a 2sk82 follower power buffer.
i have some nichicon KZ but i d be curious to know some impression of Gold Tune as coupling...or maybe it s just not a so good idea...?
Well...you can try it
