For sale is a New matched quad of JJ E34L beam pentode. Clear glass. Purchased as a matched quad new from AES a number of years ago, never ended up using them.
The tube is designed for a slightly larger negative grid voltage for a given "typical" bias condition of the EL34. This can be used to advantage in either guitar or HiFi use depending on the amp.
These are guaranteed new and very clean. Pins are shiny with no corrosion.
$40 plus flat rate shipping within CUS.
