I'm selling my Lite Audio LS7b Tube Preamp. I can live without it and I need cash for new projects!
I have it mounted in a recycled chassis without any volume control, so you would need either an external channel selector and volume control or you can modify the current layout. I used an external stepped attenuator with this.
It has a lot of gain! It would probably do well with high-power amps or with weak sources. It sports a tube rectified power supply, two 12AX7's and a 12AU7. The S/N ratio probably isn't the best, but I haven't tired to measure it.
You get the Lite Audio LS7b board, power supply, a set of tubes, schematic, and the recycled chassis. I'm thinking $175 or best offer would be cool.
I'll post photos soon. I'll also likely improve the mounting for the power supply as well.
